2020-08-05-Dual band AR's
- JochenM
- Been thanked: 1619 times
A beautiful sunny day here today and the start of an upcoming heatwave. So plenty of sun to be seen. Unfortunately; in these circumstances the seeing usually leaves much to be desired. Overall, I'm fairly happy with the haul; although I had discard quite a lot of data (including everything I captured in CaK).
Plenty of activity going on across the disk, with no less than 3 AR's to pick from. We're being spoiled!
Setup:
HA: 80ED, Quark Chromosphere, Baader 35nm H-Alpha filter as sub-aperture ERF, IMX174.
WL: 80ED, IR/UV filter, Baader Herschel Wedge, Solar Continuum Filter, 1.8 ND-filter, IMX178.
Thanks for looking!
2020-08-05-Sun-AR2768-HA-Color by Jochen Maes, on Flickr
2020-08-05-Sun-AR2770_AR2769-HA-Color by Jochen Maes, on Flickr
2020-08-05-Sun-Filaments-HA-Color by Jochen Maes, on Flickr
2020-08-05-Sun-AR2770-WL-Color by Jochen Maes, on Flickr
2020-08-05-Sun-AR2768-HA-BW by Jochen Maes, on Flickr
2020-08-05-Sun-AR2770_AR2769-HA-BW by Jochen Maes, on Flickr
2020-08-05-Sun-Filaments-HA-BW by Jochen Maes, on Flickr
2020-08-05-Sun-AR2770-WL-BW by Jochen Maes, on Flickr
Setup:
Thanks for looking!
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Re: 2020-08-05-Dual band AR's
What a wonderful set what happened to the CaK, was that a deliberate binning or a mistake? we still have no sun or any sign of this heatwave yet
- Been thanked: 4980 times
- JochenM
Thanks all.
Alexandra, I binned it on purpose (too blurry). Closeup CaK only seems to come out well here when seeing is quite good; all other times it's just a blurry mess (even when other wavelengths are just fine). I still try it almost every session for the occasional keeper though (and it's not all that much trouble just changing a filter anyway).
- Has thanked: 1188 times
- Been thanked: 1382 times
- Has thanked: 9723 times
- Been thanked: 5773 times
Hi Jochen,
Excellent images. Well done.
Hi Jochen, you've also captured some cracking images, so thanks vm
- JochenM
- Has thanked: 17853 times
- Been thanked: 16996 times
Awesome images Jochen! I love that first Ha image. The plages look like a parting in the fine fur of a cat or other animal. It makes the sun seem alive in a way. I also like the white light images. You got the little double pore. I couldn't resolve the individual pores separate today in my observations.
- Been thanked: 10489 times
Nice shots Jochen! Don't forget the effects of resolution vs wavelength - cak is 1.6x more sensitive to poor seeing than Ha.
- JochenM
Thanks guys!
James, the "furry" details of an AR in HA is also something that never ceases to amaze me. Probably one of the most visually pleasing things in astronomy you can observe (at that scale/detail at least).
Cheers Mark, that makes perfect sense actually. The way I see it; the CaK filter will essentially last me a lifetime if I take care of it (which I do). So even if I only get a handful of high res images out of it a year; still worth it!
