Poor to average seeing, but still fun to see what can be had. Best seeing was on the closeup of the sunspot at the end of the session.
Lunt 100 and asi178mm, then: 0.5x reducer for full disc image, camera only+ROI for partial disc and flare, then 2.5x for the sunspot. I tried doing a closeup of the flair without the 2.5x to see how it would turn out compared to using the 2.5x, and it wasn't nearly as good. Pixelation and and sensor pattern noise really do their damage, looking forward at some point to jumpt to a camera that doesn't use the sony exmor sensors, since they all seem to struggle with that sensor pattern issue, limiting how much of the very fine detail you can extract with them. Its most noticeable on the full size flare image, especially on the flare iteslf.
Full disc, sunspot, and light activity, 08-10-20
- AJamesB
- Has thanked: 1150 times
- Been thanked: 630 times
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
- Has thanked: 9401 times
- Been thanked: 5558 times
Re: Full disc, sunspot, and light activity, 08-10-20
Very nice images.
Very nice images.
- AJamesB
Thanks!
asi178mm
asi294mm
asi178mm
asi294mm
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
That 100 works well for you.
Dan
South central Indiana
USA
USA
- Has thanked: 20424 times
- Been thanked: 10242 times
Nice shots!
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
- Has thanked: 17648 times
- Been thanked: 8787 times
Wow!! beautiful images I can feel the heat from here
