August 10, 2020: AR12770 in H-alpha
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Hello Everyone.
Seeing was pretty bad on the 10th so these images suffer a bit of blurriness but at least it wasn't a total wash like my August 8th session.
Equipment: Aries ERF, Celestron C8 Edge, Moonlite CHL focuser, f/46 Telecentric, Daystar QPE 0.6A, (f/30 FR) Point Grey USB3 Grasshopper IMX174
There's a lot of interesting structure visible in the double spot which has evolved from the single.
Hope we all get to experience some better seeing!
AR12770 at f/30 AR12770 at f/46 Cheers.
Peter
Peter
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Re: August 10, 2020: AR12770 in H-alpha
That spot is definitely falling apart.
Dan
South central Indiana
USA
USA
Hi Peter,
Yes I can see the seeing-difficulty you experienced, but you've captured the action of 2770 - thanks vm
- Has thanked: 9319 times
- Been thanked: 6157 times
These are very good for the bad seeing conditions you had, Peter. The wider field is my favorite, showing AR2770 very well.
- Has thanked: 9723 times
- Been thanked: 5773 times
Hi Peter,
Amazing and if my calculation is correct that is at 6096 mm focal length ?
- p_zetner
Thank you all for your comments.
Terry: I was lucky enough to salvage some details in the spot umbra at f/46 even though the surrounding plage regions are not too sharp. You're right, there is a lot of action there!
Franco: I prefer the wider field version as well. The seeing didn't quite support the higher magnification.
Rainer: Yes. At f/30 the focal length is about 6 metres while at f/46 it is 9.3 metres ! Mind you, I've never actually measured it and am quoting the numbers I get from my design software (WinLens3D) with the design lens spacings. I should really try an actual measurement of the focal length!
Peter
Peter
Hi Peter,p_zetner wrote: ↑Tue Aug 11, 2020 11:40 pm Thank you all for your comments.
Peter
By pure curiosity it would be interesting to know how many km you resolve in one pixel
- Has thanked: 8559 times
- Been thanked: 8290 times
Good images, Peter. It’s always so frustrating when the conditions don’t cooperate.
Wow!! image number 2 is very spectacular, it is very interesting to see what looks like arch filaments entering the spot rather than penumbra
- Been thanked: 10489 times
Good results Peter!
- Been thanked: 4980 times
Peter:
Bad seeing but you got some good results with the 8" scope.
- Has thanked: 1188 times
- Been thanked: 1382 times
