Hi:
In CDMX (México City), the day was clear and sunny with some clouds, but the Sun was very calm, so I used the time to calibrate my observatory monitor, but the results were horrible with a deep green background, so I took apart the Spyder 2 and found that the sensor had a sort of a green filter that was very degraded, so cleaned it and tried to calibrate with and without the green filter in the Spyder 2 from Pantone.
After many tries, I took it off and the monitor got a nice calibration (well I think, compared to the others tests).
After the "calibration" I started to adjust the Solarmax 90 adjustments that had kept for many months, so I readjusted both etalons and the rest of the adjustment wheels and levers and left them as I thought gave an even FD image. (no hot spots)
Hope they are fine and thanks for looking just a few test shots, because after the last test, it clouded all over.
I am loading 4 test images, they are not finished images.
Have a nice and sunny Sunday.
Sol from the 22nd of August 2020.
- Been thanked: 4904 times
- Has thanked: 8418 times
- Been thanked: 8165 times
Re: Sol from the 22nd of August 2020.
Your adjustments look perfect, Eric. Beautiful FDs.
- JochenM
- Been thanked: 1619 times
- Been thanked: 8793 times
Some lovely full discs Eric
I too have had to by an Xrite 1pro to try and calibrate my new laptop screen. It didn't come with any instructions but I think it did something, the colours seem more like my old computer but I do still get strange grading artefacts in the blacks and some of my greyscale images have a strange pink grey in them? I have absolutely no idea what is going on but I think it has improved matters (couldn't be any worse )
Alexandra, Stu and Jochen:
Thank you for commenting and reading the usual things that always happen to us amateur astronomers.
Alexandra, I calibrate all my old PC´s at the rural and home observatories with the Spyder 2 kit from Pantone, but at home for my newest (5 years old) PC that I use for work and for processing all my recordings, I use the X.rite Color Munki.
Stu and Jochen, yes the last FD is the most even from the tests I made, but now I have to wait for a clear sunny day to recheck the adjustements and find out if a flatter image looks too "flat" to finish up the image, that is that the image lacks of interest.
Well wish you all a nice day and a fruitful comming week.
- Has thanked: 9145 times
- Been thanked: 6027 times
Hi Eric: they may be test images, but look great to me.
- Has thanked: 17581 times
- Been thanked: 16697 times
Eric,
You live in or near Mexico City? Nighttime observing would suck so doing solar is certainly the way to go. Nice images as usual.
- grimble_cornet
- Been thanked: 47 times
Good use of a 'blank disc' day Eric!
As others have said, number 4 looks very good indeed and I look forward to seeing your next post with a bit more action on the surface.
Mike Garbett
Mike Garbett
Franco, James and Mike:
Thanks for the kind comments.
James, I live in México City, so you can imagine the light pollution.
I just can observe the Sun. Moon and some Planets, at the home observatory I have scopes up to 102mm of aperture.
I also have a homemade optics 12.5" f/6 Newtonian on a Dobsonian wooden mount, but seldom I can use it.
