Today's SUN (20200825) | Paramount ME, and more
- pedro
- Has thanked: 14 times
- Been thanked: 6578 times
WEB LINK:
http://pedroreastrophotography.com/sun_ ... 20-08.html
Check out a new setup that I plan to use shortly to image the Sun (Paramount ME). It will be housed in a third observatory (roll-off-roof 2x2m)
PARAMOUNT ME (20200825) | Pedro RE'
Solar imaging session (20200825) | Pedro RE'
TV101, LUNT60
GS3-U3-28S4M, Takahashi EM-400
SUN (20200825) H-alpha PROMS (08:00 UTC). LUNT60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20200825) H-alpha PROMS (08:00 UTC). TV101 F/5.4, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20200825) CaK PROMS (08:00 UTC). TV101 F/5.4, LUNT 1200 CaK Module, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20200825) WL, CaK & H-alpha (08:00 UTC). TV101 F/5.4, LUNT 1200 CaK Module, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
WEB LINK:
TV101, LUNT60
Pedro Re'
- Has thanked: 17581 times
- Been thanked: 16697 times
Re: Today's SUN (20200825) | Paramount ME
WoW, Pedro. Paramount is among the best. The weight capacity of that mount has to be impressive. Nice images too. Unless I get lucky I probably will not get to observe today. Clouds and rain predicted.
- pedro
Thanks James
I have two paramounts ME. This one will be used for imaging the sun and other targets as well
Pedro Re'
Impressive, Pedro, Impressive!
- Been thanked: 4904 times
Pedro:
The ME is a sturdy mount, I have an old one with the TDM (Telescope Drive Master) with encoder and works really well with the mounted 12" f/8 RC and the Epsilon 180mm.
Looks like I still have very old mounts like the Byers 812, the A-P 1200GTO (with a TDM encoder too), a Losmandy 200 and even a Cavel and an Edmunds mounts.
Best regards and fuerte abrazo.
Excellent news Pedro on the newbie mount.
I guess that something in the order of a 300mm scope or several smaller ones will be fitted in due course, so should be interesting...
With around 218 Kgs/480 lb total instrument capacity, it certainly allows for so many options as well as the smooth belt-driven capabilities too.
Excellent video and thanks vm
Regards
Regards
- pedro
Thanks guys
I plan to use a TMB175 F/8 and a RCOS 10" F/9 with this mount and a couple of refractors to image the sun as well (TEC140 F/7 & APM180 F/5)
I still have to build the roll-off
Back in the day I had a C14 with a Byers retrofit (it's sold now). It had the best Byers worm gear I used so far
- apm180_f6_20190106_mosaic.jpg (2.1 MiB) Viewed 901 times
- peres_gomes_20060521.jpg (166.36 KiB) Viewed 903 times
- tmb175f8_20170603-01.jpg (1.13 MiB) Viewed 903 times
- TMB175_F8_Riccardi_1X_FF_20200728-04.jpg (789.9 KiB) Viewed 903 times
- tmb175_f8_20170613_mosaic.jpg (997.53 KiB) Viewed 903 times
- pedrore_winter.jpg (49.21 KiB) Viewed 907 times
Pedro Re'
Re: Today's SUN (20200825) | Paramount ME, and more
Stroof !! Pedro, That certainly is some huge gear you've shown us.
But what is that large box-like silver/grey item, complete with the RS-232 and USB ports etc., and noting that there are two pipe-connections (for water or nitrogen-cooling a camera) ??? TMB175_F8_Riccardi_1X_FF_20200728-04.jpg (789.9 KiB) refers ?
- JochenM
- Been thanked: 1619 times
That's a nice setup you're putting together there, Pedro. Should provide lots of fun for many years to come!
- Been thanked: 8793 times
Some lovely prominences around the disc Pedro and nice to see you getting even more new toys to add to the collection
- pedro
Thanks guys
The huge grey box is a SBIG STL11000 CCD camera. I use these cameras to image the deep-sky
Pedro Re'
- Rusted
- Has thanked: 8016 times
- Been thanked: 1938 times
Dear Pedro,
You have some lovely "toys."
Have you considered trying a roll off building for the new solar set-up?
You might enjoy improved seeing conditions without having a solar heated wall just below the telescope objectives.
I have often wondered how warm your present dome gets.
I often see up to 8F differential between [shade] air temperatures inside and outside my open and well ventilated, plywood dome.
Moreover, a raised thermally neutral [wooden?] platform might get you above local, ground convection currents.
- Been thanked: 171 times
Lovely Pedro. Did you purchase this second hand or brand new? The reason I ask is that I am thinking about purchasing a bigger mount than my EQ 6 and there are limited suppliers down here in Australia of quality mounts but Paramount is one.
Derek
Derek
Hey Pedro Do you have any other Coronado scopes besides a PST? Just curious. You have a lot of scopes!
- pedro
Hi James
I have several Coronado Pre-Meade SM etalons (SM90II, SM60, SM40). The second Paramount was a gift from a close friend
I do not have other Coronado Scopes apart from the PSTs (I have 3)
Pedro Re'
- pedro
I will build a roll-off-roof for the second Paramount. It will be my third observatory. It will be a 2x2m roll-off
My dome gets warm during the day but I image early in the morning most of the times
I hope I will have it in a couple of months
Pedro Re'
I was just curious of your assessment of them, especially the Meade ones. But if you don't have one you cannot rate them.
- pedro
My experience tells me that generally the Pre-Meade etalons are much better that the new ones. I tested several Pre-Meade Coronado 90 (single and double stacked) and they were very good
Pedro Re'
- pedro
The new roll-off will be similar to this one. 2x2m with aluminium walls (wallmate inside).
- roll_off_rui_goncalves_20200327.jpg (973.04 KiB) Viewed 738 times
Pedro Re'
Pedro,
I hear the Meade ones vary more in quality than the older ones. Some being quite good and others not so much. Mine seem to be decent but I do wonder about my SMII60 sometimes. It rarely does well at even moderate magnifications. I tend to use it most often in the 16x to 33x range. Low power. Details fade rapidly as magnification increases.
Nice roll off. In time I may get a setup, an observatory. This would be awesome!
- Been thanked: 10248 times
You have some nice equipment Pedro.
Where did you get the roll off from in the last photo?
- pedro
Thanks Mark
The roll-off was recently built by a Portuguese friend (Rui Goncalves). It houses a C14 that I owned a few years ago
My plan is to build something similar to house the second Paramount ME
Pedro Re'
