CaK with 250 mm RCT- REWORKED!
- Has thanked: 8543 times
- Been thanked: 8280 times
Inspired by Alexandra's Ca K images with her C11 I thought I'd take an opportunity on a sunny lunch break to see what I could do with my 250 mm RCT. Previous attempts were a complete failure (for whatever reason) and although lunchtime isn't the best time of the day for hi-res work I wanted to undertake a trial run to see if the previous issues remain. I think better collimation and a B1800 CaK module (as opposed to a B600) may have made the difference, plus improved processing knowledge, but the results this time around are a world away from the previous mess.
Anyhow here's the result in mono and colour. By no means perfect and much room for improvement, but the scope shows significant promise under optimal seeing conditions. I need to somehow brighten the image (by modifying the CaK module) to significantly reduce the exposure time and freeze in the air movements..... my next project
20200901_CaK_x2.7_2 by Stuart Green, on Flickr
20200901_CaK_x2.7_2_Colour by Stuart Green, on Flickr
Thanks for looking.
Thanks for looking.
- pedro
- Has thanked: 14 times
- Been thanked: 6689 times
Re: CaK with 250 mm RCT
Beautiful HR Ca-K images Stu, well done
Pedro Re'
- Has thanked: 20779 times
- Been thanked: 10462 times
You're being ambitious there Stu, 250mm at CaK is the equivalent of imaging at 400mm in Ha. Have you ever tried your 150mm scope for CaK? at f10 you should be a winner, or is it a faff taking the Ha rear end off? When you can get results at 250mm in Ha, then 150 in CaK is equivalent in resolution.
- Has thanked: 17970 times
- Been thanked: 8905 times
Wow!! amazing Stuart!!
Did you stop the aperture down? did you use the 2.5x powermate?
Re: CaK with 250 mm RCT- REWORKED!
Same images as above, but reworked using different settings in ImPPG.
20200901_CaK_x2.7_3 by Stuart Green, on Flickr
20200901_CaK_x2.7_3_colour by Stuart Green, on Flickr
I guess these are too ‘fluffy’ for CaK, which should be more ‘flaky’ according to images from DOT, if this is the benchmark.
Thanks for looking.
Thanks for looking.
Hi Mark,marktownley wrote: ↑Wed Sep 02, 2020 4:48 am You're being ambitious there Stu, 250mm at CaK is the equivalent of imaging at 400mm in Ha. Have you ever tried your 150mm scope for CaK? at f10 you should be a winner, or is it a faff taking the Ha rear end off? When you can get results at 250mm in Ha, then 150 in CaK is equivalent in resolution.
I completely understand what you mean because of the shorter wavelength of Ca II K compared with Ha and it would be interesting to try the 150 mm, but the main issue is the internal ERF which really would be a faff to remove every time.
Hi Alexandra,
Many thanks. I figured I'd try it at full aperture to see what I could get. No, the PM gives a central image that is far too bright. Instead I image in CaK using an APM 2.7x Barlow from Rupert at Astrograph, with good transmission at 393.4nm.
I thought there were constraints that meant the 150 wasn't feasible.Carbon60 wrote: ↑Wed Sep 02, 2020 6:38 pmHi Mark,marktownley wrote: ↑Wed Sep 02, 2020 4:48 am You're being ambitious there Stu, 250mm at CaK is the equivalent of imaging at 400mm in Ha. Have you ever tried your 150mm scope for CaK? at f10 you should be a winner, or is it a faff taking the Ha rear end off? When you can get results at 250mm in Ha, then 150 in CaK is equivalent in resolution.
Stuart, to use the 2.5x powermate all you have to do is add 4cm to the end of it before the camera, works a treat.
- grimble_cornet
- Been thanked: 47 times
Great images Stu and overall very interesting stuff. I can use my 100mm f10 Tal most days for CaK and with two x2 Barlows stacked together I have had very sharp results on days of really good seeing. I have tried using the CaK1200 unit on my 152mm f5.9 scope with promising results - I have a near full aperture erf which just sits on the end of the tube (thanks Mark) so its easy for me to swap between Ha with the Quark, white with a Baader wedge and CaK. Look forward to seeing more results in high res CaK from you and Alexandra.
Mike Garbett
Mike Garbett
