Just had a quick look with the 90mm F6.7 28.5mm baffle 35nm 10mm Baffle 2x ES Tele-extender Prom Quark
Meade 32mm SP
01.40 BST
05.30 Jet slightly wide, seperated from surface, knotted.
Fujiyama 25mm Ortho Occulting segment
05.30 Three knots hint of bars down from the first and third ones. Top one slightly flared pointing up.
Three bumps in the spicule layer above
02.00 BST
05.30 Bright jet above, from first bump?, leaning down to first knot at 45deg
The original jet thinner seperated jet with fuzzy top.
'Thats all folks' - seeing not good but a couple of scans round did not reveal any other signs.
Cheers. Andrew.
19/09/2020 Visual Report
- Has thanked: 3315 times
- Been thanked: 1907 times
- Has thanked: 20783 times
- Been thanked: 10467 times
Re: 19/09/2020 Visual Report
Glad you got a view in Andrew!
- Been thanked: 8905 times
The reports are getting shorter I hope soon they will get longer
