Imaging from home (T300 Solar newton, K-Line
- Has thanked: 714 times
- Been thanked: 496 times
I was quite happy about the picture taken from 3000 altitude (St Véran, French Alps) last year and this year.
I wanted to try the same setup in my area, in the "heights" of Belgium, at about 600m altitude.
Here, the best result after selecting and some tweaking + image size reduction:
The full resolution is here.
Because of the extensive treatment (Deconvolution + denoising) I needed to apply, I'm afraid I will travel once more to the French Alps for imaging.
CS
Alex
2020-09-14
Sourbrodt (600mAlt.)
T300 solar
FFC
KLine
ASI174
CS
Alex
2020-09-14
T300 solar
FFC
KLine
ASI174
- Has thanked: 17572 times
- Been thanked: 16689 times
Re: Imaging from home (T300 Solar newton, K-Line
Very nice. What scope? What aperture ? 300mm?
- Has thanked: 9143 times
- Been thanked: 6024 times
- Been thanked: 4904 times
- rsfoto
- Has thanked: 9401 times
- Been thanked: 5558 times
WOW, just WOW to see the rice grain in such a magnification ...
I love granulation images. The individual granules are so small they test the scope and seeing. To get them like this says a lot positive for both. And to the skills of the imager as well!
Getting them like this visually is not easy either. Contrast is pretty low and a filter, like a 540nm green filter seems to help me. But I have never seen them near this well. An imager can increase contrast like no filter can and I am limited by aperture. I don't have anything outfitted for solar beyond 102mm.
- Has thanked: 20424 times
- Been thanked: 10242 times
Very impressive indeed!
- Been thanked: 4900 times
Excellent granulation imagery Alex.
Thanks vm
Thanks vm
Wonderful granulation images with lots of detail!
Would you mind to elaborate on your remark about deconvolution and denoising? Which software did you use for that, in particular for denoising?
I'm asking because captured a couple of granulation videos last week, and my processing attempts were not successful so far. Sharpening with imppg I keep getting a granulation pattern spoiled by lots of dots and wrinkles that look like sharpened noise. Using Registax I can reduce the noise, but the images come out too soft, so I'd appreciate hints how to denoise granulation images!
Kind regards,
Frank
Kind regards,
Frank
I get this if I use LR in ImPPG, I use USM (for CaK) in ImPPG now and don't get it...
- Been thanked: 4340 times
Absolutely marvellous image Alex...well done
- Has thanked: 17648 times
- Been thanked: 8787 times
Absolutely fabulous it is wonderful to see the K grains too
I use NeatImage for denoise and love it, I couldn't live without it now.
- Martin_S
- Has thanked: 979 times
- Been thanked: 2992 times
I just tried this method Mark, the results are really good.marktownley wrote: ↑Sun Sep 27, 2020 2:18 pmI get this if I use LR in ImPPG, I use USM (for CaK) in ImPPG now and don't get it...
Martin
Sorry, I was off yesterday.
Thank you for the nice comments.
The scope is indeed a 300mm aperture.
I was using Neatimage in the past to denoise, the free version however.
The free version supports only 8bit.
So I decide to denoise under Pix Insight. It allows various denoising possibilities.
I used ACDNR (Adaptive Contrast-Driven Noise Reduction).
For the deconvolution also, I used Pix Insight.
I tested various functions, but I can't remember which one I kept. Probably a deconvolution with Van Cittert function.
CS
Alex
CS
Alex
- Martin_S
could you post a raw unprocessed image Alex? . Your finished results are impressive.
Martin
Martin
Thanks, Alex! That's enough information to start! I haven't used PI for solar images yet, but I'll definitely try that.
Together with Alexandra's and Mark's suggestions I have now a variety of possible ways of getting rid of the noise to try out, and next week I will hopefully have a bit of time for that!
Frank
Frank
- pedro
- Has thanked: 14 times
- Been thanked: 6573 times
Fantastic image Alex
Pedro Re'
Thanks again for the interest and the comments.
Sorry, I'm not a very regular on solarchat.
I know solarchat from the time before the forum has this form; it was already having very interesting posts and articles.
I forgot to mention that the scope is a non aluminized solar newton, on truss structure.
Martin, here a jpg of the aligned/stacked pic out of autostakkert.
It is a stack of 50 pics.
I can provide the full 16bit version. Please, send me a mail
allhoest at scarlet.be
CS
Alex
CS
Alex
- 20200914_101425_lapl3_ap6611(Stack 051)_60Pct.jpg (102.52 KiB) Viewed 895 times
