4th November 2020 3-light Solar images
Well today was definitely a bonus for CLEAR SKIES, where i was able to spend much more time (than of late) without those "Pesky" clouds interfering.
After various adjustments to previous imaging and trials of FireCapture, as well as a new piece of hardware too - it was a successful day, albeit a bit on the chilly-side of late, but well worth it...
The new-gear trialled through the Orion-ED80T-CF scope with Hershel Wedge for that white light was successful in showing the AR2781 on it's own screen and eventually can be connected to a computer and separately record the captures. This is a "REVOLUTION R2 IMAGER" system - from the U.S.
I'll further blocks of images a little later, as zillions of captures are yet to be processed... (perhaps i will have to employ a secretary to do the honours with that processing. On the other hand, perhaps not)...
Thanks for looking and CLEAR SKIES
- 2020-11-04 1100z Cak.jpg (827.49 KiB) Viewed 464 times
- P1040845 EGRAY OBSERVATORY.jpg (582.14 KiB) Viewed 464 times
- Has thanked: 9723 times
- Been thanked: 5773 times
Re: 4th November 2020 3-light Solar images
Hi Terry,
Nice equipment you have there. The CaK image looks like if you overdid it with the wavelets or sharpening. ¿?
- Has thanked: 976 times
- Been thanked: 344 times
I'll swap my cloud for your clear
That blue is rather blue
Call me Geoff.
I do what I do because I want to, and because I can....
Doesn't mean I know what I'm doing, though!
Thanks Rainer, your sharp-eyes have caught that out, so the next set of Calcium-K images may or may not have that problem to correct.
They will posted here...
indeed Geoff we here in the S.E. certainly had one of those nice blue skies and when more jets are grounded (hopefully) could even be a repeat of May'20 with deep-blue skies...
These are the next set of Calcium-K images processed.
Hydrogen Alpha and White Light etc., will follow soon...
Tomorrow will try 2.5x TV PowerMate etc...
Thanks again for looking
- 2020-11-04 AR2781 - Calcium-K close-up.jpg (37.29 KiB) Viewed 445 times
- 2020-11-04 1103z Cak AR2781.jpg (1.67 MiB) Viewed 445 times
- 2020-11-04 1100z Cal-K 100---frames.jpg (566.89 KiB) Viewed 445 times
- 2020-11-04 1059z AR2781 CAK.jpg (416.03 KiB) Viewed 445 times
- Has thanked: 17853 times
- Been thanked: 16996 times
Terry,
I love your setup!
I love your setup!
Thank you so much James and soon the R2 will be added. (What is the "R2" - some may ask !!! All will be revealed - shortly...
Now is the time for the last of the captures today (more or less), which include both Ha and WL.
I'm always up for comments (bad or good) as it helps me to improve - slowly !!!
Thanks for looking
Thanks for looking
- 2020-11-04 1319z WL + 50mm F-Stop.jpg (10.95 KiB) Viewed 430 times
- 2020-11-04 1113z ED80 + HW.jpg (12.36 KiB) Viewed 430 times
- 2020-11-04 1050z AR2781 .jpg (9.21 KiB) Viewed 430 times
- 2020-11-04 1040z AR2781 FLARING.jpg (18.92 KiB) Viewed 430 times
Terry,
What make of scope is the CaK instrument?
James.
James.
Hi James,
Both the 60mm SolarScopes are Lunt as:-
LS60THaFT/B1200 LUNT 60mm Hydrogen-Alpha/FeatherTouch/B1200 Blocking-Filter
LS50FHa LUNT 50mm Ha Double-Stack Filter
LS60Cak/FT/B1200 LUNT 60mm Calcium-K/FeatherTouch/B1200 Blocking-Filter
I have just completed all the processing of today's event, including the R2, so will put that on a separate post now.
If you have any further questions, please ask...
- Been thanked: 4427 times
Great pics and setup as well Terry!!!
Glad to hear you had clear skies to work with too.
- Has thanked: 8559 times
- Been thanked: 8290 times
Hi Terry,
Can you talk us through your work flow? Have you tried using ImPPG in your process steps for deconvolution and sharpening?
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
- Has thanked: 20819 times
- Been thanked: 10489 times
Hi Terry looks like you've been having fun.
Is your imaging workflow in 16 bit? ie autostakkert is outputting a 16bit Tiff file which is being processed in 16 bits in Paint shop Pro?
Thanks Brian and yes I had been longing for a few hours of Sun-shine, which is helping me to improve. Unfortunately today, fog at first and now have to do something else in the nice-blue sky.
Thanks Stu - I do of course have iMPPG and many other progs for processing etc., but still in the early-stages of getting the scopes adjusted properly, followed by the capture progs, which has taken for ages due to the weather here. I tried Fire-capture yesterday, but even though it is quite (over) complicated compared to SharpCap, the only result near the end of the possible-session, didn't really show any improvement over SharpCap.
So ideally I've started all over again from the beginning since July'20 - with all the mods here, whilst also trying to learn from the SolarChatters here with their fantastic imagery... The basic work-flow is usually on each image...
Thanks Jochen. I've had that mount since 2017 specifically to carry the load, as the Vixen GP mount was struggling with that payload.
Thanks Mark. Yes, probably the most fun-day for years. AS!3 is definitely outputting TIFF's and I will get back to you about 16bit which I believe it is.
CLEAR SKIES
CLEAR SKIES
