Hi James, much depends on which camera you have available.
Obviously in the case of the ZWO ASI 178MM, it comes with it's own "1.25" T-Mount" to simply replace an eye-piece.
Some makes of DSLR's have available to purchase "T-Mounts" of which my Panasonic DMC-G2 has one and in 2010 I was taking good images through both the Lunt 60mm Ha and Cal-K scopes, as well as through a 114mm Reflector in WL too.
They can be available for 1.25" or 2" version for fitting to the scopes focus-draw tubes.
Usually the T-Mount consists of two-parts as the camera's mount-type and the T-adapter itself..
Other cameras similar to DSLR's may also have available "T-Mounts" but in all cases web-searching should assist in finding which and suppliers.
Alexandra says the word "snout" which I think means the same as "T-Mount" - Apologies in advance Alexandra if I'm wrong there...
Attached images show both the T-Mount as well as a WL filter for my DMC-G2 camera.
ZWO ASI178MM Monochrome Camera
Re: ZWO ASI178MM Monochrome Camera
- IMG_1761 WL-FILTER.jpg (1.53 MiB) Viewed 440 times
- IMG_1760 T-PIECE.jpg (2.46 MiB) Viewed 440 times
- Has thanked: 17845 times
- Been thanked: 16977 times
Yes it did come with a snout to fit the eyepiece holder. It fits perfectly.Montana wrote: ↑Tue Nov 10, 2020 10:05 am James, the camera should come with a snout which fits inside an eyepiece holder, my ASI did. You shouldn't do eyepiece projection, just remove your eyepiece and pop it in instead. Always best to find the Sun with the eyepiece first, then do a straight exchange and the Sun should be in the field of view.
And yes Terry I have one for my Nikon too.
- Has thanked: 9710 times
- Been thanked: 5769 times
Hi James,DeepSolar64 wrote: ↑Tue Nov 10, 2020 2:09 pmYes it did come with a snout to fit the eyepiece holder. It fits perfectly.Montana wrote: ↑Tue Nov 10, 2020 10:05 am James, the camera should come with a snout which fits inside an eyepiece holder, my ASI did. You shouldn't do eyepiece projection, just remove your eyepiece and pop it in instead. Always best to find the Sun with the eyepiece first, then do a straight exchange and the Sun should be in the field of view.
Yes find the Sun with an eyepiece and exchange to camera but I doubt it will be in focus. As far as I know the focus of an eyepiece is inside (depends on the eyepiece type) as an eyepiece has a negative focal plane and the camera need a positive focal plane or however it is called ...
IMHO
Look here https://en.wikipedia.org/wiki/Eyepiece
Perhaps you will need an extension ¿? This is Trial & Error work ...
I guess people with more experience then me can explain better how it behaves.
I am sure a lot of my initial imaging attempts will be trial and error.
Again, as Rainer says there will almost certainly be different focusing and my experience of 10-years ago with the Lunt 60 and my as camera imaged, didn't take much to get to focus. Of course the Lunt 60 does have quite long draw-tube as well as the Blocking-Filter can also be adjusted in the draw-tube, as well as the camera itself into the BF too, so unlikely to be a problem.
Depending on your Nikon camera's type, if it has a separate back-mounter monitor as can be seen on my G2, then it will be "easy-peesy" to use that monitor for aligning the scope and even focusing. Mine has the choice of using the back-monitor and/or the view-finder..
I will likely be using my G2 for WL imaging (along with the R2) - whilst the Sun is low-down...
ps 3-pages and zillion of looks for this post !!
I installed the drivers and the ZWO imaging software plus an older version of SharpCap on an old Windows 7 laptop I have. Using the camera's tiny all-sky lens I got it to work but the computer seems terribly slow running it. The video image is quite jerky with some delay. I may have to use my wife's Windows 10 laptop for this. This old computer I am using is probably a 2009 model!
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Be sure to use a USB3 port James. USB2 really slows it down.
Dan
South central Indiana
USA
USA
That may be the issue I am having with this old machine . The image is quite jerky.
As Dan has said, as the ASI 178 runs faster on USB-3 through its' own USB-3 cable, as long as the pc has a USB-3 port, otherwise there should not be too-much difference from plugging the USB-3 cable into a USB-2 port.
Trying selecting in the SharpCap program both USB-3 AND USB-2 as the method to be used - to see if that helps.
My observatory-computer has been programed with Windows-7 Professional and I know that either USB-3 PORT and USB-2 PORT usage makes little difference to the download times for Solar imaging, as the download files are much smaller than long night-time imaging. Also taking "SNAPSHOTS" for a start, uses very little pc memory...
Keep the number of programs open on any pc, down to the minimum, as they all can slow-down the performance too..
