14Nov - AR2781/2 in CAK & HA (Single frame CAK Image added on 18 Nov)
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
14Nov20. Cloudy and average seeing. The Setup:
ARIES D-ERF mounted on Celestron C11 fitted with Chroma CAK filters in Skybender, x2.5 Televue Powermate and ASI174MM camera.
Saw 2 micro flares on outgoing AR2781
The image was formed by stacking 25 frames selected from a 1,000 frame recording. Shutter was set at 1.961ms and Gain=222. Level increased slight contrast adjustment was done in PS. No denoising or any sharpening.
Do a right click to see the image in its full resolution.
Alfred
Alfred
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- Has thanked: 8558 times
- Been thanked: 8290 times
Re: 14Nov - AR2781 in CAK
Nice image, Alfred. Lovely Ca II K.
Stu
Stu
Very nice image, and great resolution! Would you mind to tell a bit more about your experience with the Chroma filters?
And one more question: Did you try some unsharp mask? (I also clearly prefer slightly soft images to oversharpened ones, but I still suspect you might get a bit more sharpness.)
Kind regards,
Frank
Kind regards,
Frank
- yltansg
Hi Frank,LTHB wrote: ↑Sat Nov 14, 2020 1:21 pm Very nice image, and great resolution! Would you mind to tell a bit more about your experience with the Chroma filters?
Frank
Thanks for your kind comments.
I have tried using Daystar Calcium Quark, Lunt CAK wedge and Chroma filters. So far, the Chroma filters produced the best result. Unfortunately, I am beset by poor weather. I hope to do better with better weather.
I prefer soft images too but may occasionally do some sharpening
Alfred
- yltansg
- Been thanked: 4980 times
Re: 14Nov - AR2781/2 in CAK (New Image added)
Alfred:
Beautiful CaK images.
Very well done.
Send my best regards,
Very well done.
- Has thanked: 20813 times
- Been thanked: 10480 times
There's definitely a synergy with the C11 and the 2.5xPM in CaK images which works well. These came out excellent Alfred, were you running full aperture?
- yltansg
Hi Mark,marktownley wrote: ↑Sat Nov 14, 2020 3:52 pm There's definitely a synergy with the C11 and the 2.5xPM in CaK images which works well. These came out excellent Alfred, were you running full aperture?
After previous attempts and advice from this forum, I usually put a mask when doing CAK imaging. Frankly, this time round, after a long 2 months' break I forgot about the mask. The imaging was done earlier in the morning when the Sun is about 16 Deg above the horizone. I believe I should get better quality image if I were use the mask Thanks for your question.
Alfred
- yltansg
Re: 14Nov - AR2781/2 in CAK & HA (New HA Image added 15 Nov)
Here is an image taken on 12 Nov at 7:50 am using the same D-ERF and setup with a Daystar Quark Chromosphere:
Please do a right click to see the image in full resolution.
Seeing was average. Again I only did a little level and contrast adjustment in photoshop. You are seeing the image without much processing.
Alfred
Alfred
Excellent imagery Alfred.
Thanks for sharing
Thanks for sharing
- yltansg
I did 3 video recordings before thunder and lightning came upon us.
Equipment used as same as on 14 Nov: ARIES D-ERF mounted on Celestron C11 fitted with Chroma CAK filters in Skybender, x2.5 Televue Powermate and ASI174MM camera. The camera setting: Shutter=5.742ms, Gain=222. A 9" aperture mask was used.
This is a cropped image of AR12782:
Alfred
Alfred
Re: 14Nov - AR2781/2 in CAK & HA (New Hi-Res CAK Image added on 15 Nov)
Great additions Alfred, I like the minimal post processing approach.
- Martin_S
- Has thanked: 999 times
- Been thanked: 3060 times
Great results alfred.
- Has thanked: 17849 times
- Been thanked: 16991 times
The supergranulation is quite apparent in some of these,
- yltansg
Hi Dan, Stu, Frank, Eric, Alexandra, Eric, Terry, Martin and James,
Thanks for your kind comments. The earlier investigative work on getting rid of the bright reflection (associated with the Televue x2.5 Powermate) was worth it. The C11 + skybender + Chroma CAK filters + ARIES D-ERF is a winning combination.
Alfred
Alfred
- yltansg
Hi James,DeepSolar64 wrote: ↑Sun Nov 15, 2020 6:34 am The supergranulation is quite apparent in some of these,
It is especially meaningful (getting the supergranulation cells) because I apply very little processing. I am also very glad to see the 3-D effect in the last CAK image.
Alfred
You did well Alfred. Looks good.
- Been thanked: 2725 times
Very interesting Alfred !
Have you made other tests with the Alluxa 1 A Ca K filter ?
- Has thanked: 9318 times
- Been thanked: 6155 times
Superb close ups, Alfred !
- yltansg
Hi Christian,
Testing the Alluxa filter will be next
Alfred
Alfred
- yltansg
AR12781 (in CAK wavelength) making its exit on the western limb.
Please right click to see it in full resolution.
Alfred
Alfred
- Been thanked: 4426 times
Re: 14Nov - AR2781/2 in CAK & HA (New 2781 CAK Image added on 16 Nov)
These are all superb images Alfred...nicely done
- yltansg
Hi Brian,
For those who are curious, a single frame raw capture (without any processing) looks like this:
I would say the single frame capture is rather good quality and that was why I didn't have to do much post processing to get the final image.
Alfred
Alfred
- JochenM
- Been thanked: 1619 times
Re: 14Nov - AR2781/2 in CAK & HA (Single frame CAK Image added on 18 Nov)
Excellent work there, Alfred. That single frame by itself already looks quite sharp and detailed indeed.
- yltansg
Dear Alex,
I bought a pair of the Chroma calcium filters ( a 1-angsttrom and a 10-anstrom filter) from Apollo. I understand that these filters are the only 2 ever made. This is how I set it up:
- The 10-angstrom filter which rejects everything but a 98% transmission line at 393.4nm, is placed on the nose of a Skybender.
- The 1-angstrom filter which has 94% transmission is installed in the skybender and used for tilt tuning.
I will be testing Alluxa-Apollo CAK filters next.
Alfred
