AR2786 & AR2785 and Proms | Nov 24th 2020
- Been thanked: 1390 times
Hey all,
AR2786 is still kicking up some great dust, well, plasma! Lots of surge prominences going on and some minor flaring, and some new proms have developed around the eastern limb. AR2785 is still towing it along and making a great pair. You can see AR2786's companion pore trailing it ever so slightly in the photosphere, looks like a neat dipole. Seeing was average to poor, was around 1.1 to 1.6 arc-seconds all morning unfortunately, so stayed in the 120mm aperture range. Wasn't able to get calcium at this scale in this seeing conditions unfortunately, had to stay in the red ranges. AR2786 has some gnarly plasma fingers going into it's nice big spot with a great big penumbra.
B&W:
Color:
Seeing Conditions:
Equipment:
120mm F10 Refractor
Baader Red CCD-IR Block Filter (Internal 2" D-ERF)
PST Etalon + 10mm HA BF (HA) + ASI290MM camera
10mm HA BF (WL) + ASI290MM camera
B&W:
Color:
Seeing Conditions:
Equipment:
120mm F10 Refractor
- Has thanked: 8588 times
- Been thanked: 8324 times
Re: AR2786 & AR2785 and Proms | Nov 24th 2020
Beautiful images, Marty. It’s an impressive sight.
- Has thanked: 9816 times
- Been thanked: 5823 times
Hi Marty,
Excellent images.
Excellent images.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Marty, your poor seeing is my every day seeing. Lots of action in your images, thanks.
Dan
South central Indiana
USA
USA
Fabulous set of images Marty.
Thanks for sharing.
Thanks for sharing.
- Been thanked: 5016 times
- Has thanked: 17955 times
- Been thanked: 17100 times
The 4th and sixth images at first glance look like WL images but I noticed differences like the small bright spots around the sunspots, Ellerman bombs maybe which told me you are probably in the blue wing of hydrogen-alpha. Then I noticed the 656nm wavelength in your text confirming this. Nice capture Marty. I have never seen Ha capture spots quite this well!
Hi James,DeepSolar64 wrote: ↑Wed Nov 25, 2020 6:31 am The 4th and sixth images at first glance look like WL images but I noticed differences like the small bright spots around the sunspots, Ellerman bombs maybe which told me you are probably in the blue wing of hydrogen-alpha. Then I noticed the 656nm wavelength in your text confirming this. Nice capture Marty. I have never seen Ha capture spots quite this well!
They're mostly continuum in the image, but they were captured using just my 10mm HA blocking filter (5~7A bandpass, centered on 656nm). When I raise shadows hard, I can see spicules and proms on the limb, but very faint. Anyhow, this is the result of the blocking filter without an etalon, so basically a narrow HA filter but not narrow enough to stop out the light of the photosphere, so some features are gently merging.
- Has thanked: 9387 times
- Been thanked: 6199 times
Marty: these came out really well, beautiful detail showing.
- Lowjiber
- Has thanked: 238 times
- Been thanked: 109 times
Stunning images, Marty! Thanks for the shares.
Clear Skies
Clear Skies
John
Lunt 60 PT B/1200, Quark-Chromosphere, and ZWO ASI120MM & ASI174MM Cams.
- Has thanked: 18105 times
- Been thanked: 8941 times
I really like the first picture, so much activity and like a giant whirlpool does the pseudo WL need a vertical flip though?
Does it require any kind of filter before it like an ERF at the objective or a ND filter at the eyepiece? Would this work visually?MalVeauX wrote: ↑Wed Nov 25, 2020 11:17 amHi James,DeepSolar64 wrote: ↑Wed Nov 25, 2020 6:31 am The 4th and sixth images at first glance look like WL images but I noticed differences like the small bright spots around the sunspots, Ellerman bombs maybe which told me you are probably in the blue wing of hydrogen-alpha. Then I noticed the 656nm wavelength in your text confirming this. Nice capture Marty. I have never seen Ha capture spots quite this well!
- Has thanked: 141 times
- Been thanked: 240 times
Scary good
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
12nm Filter
