Sol from the 24th of November 2020.
- Been thanked: 4904 times
Hi:
Between work and going shopping with my wife, I had a quick chance to get some images.
Thanks for looking, the mosaics are better seen in another window.
Seeing was not good, but something came out, used the Solarmax 90-DS for the FD´s and the 102mm f/28 Stellarvue with an old Daystar t scanner.
Have a sunny day tomorrow and keep safe.
Best wishes to all.
Best wishes to all.
- Has thanked: 1171 times
- Been thanked: 1360 times
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Re: Sol from the 24th of November 2020.
Wonderful images Eric. With those SSM results I'm surprised they came out so well.
Dan
South central Indiana
USA
USA
- Been thanked: 4786 times
Marty, Dan and Maurits, thanks for looking.
Well Dan, seeing was not good as you can see, but what I do is to try to get the cadence of the seeing, and just shoot when I see at the monitor that the seeing is better, so I pause the recording when the bad part of the cadence is showing. You get used to the timing and it works.
I haven´t used the SSM trigger yet, but probably it would work better.
I also refocus in each new recording, so the cadence changes a bit too. I shoot 600 frames and align and stack 25% of it.
Best regards and have a good day.
- Been thanked: 8791 times
- Been thanked: 16694 times
Wonderfully sharp!
- Has thanked: 9145 times
- Been thanked: 6025 times
Beautiful, Eric ! We are lucky and excited to have all of this activity all of a sudden.
Agreed Franco and Eric you have well captured that action so well with the excellent images
Thanks vm
Thanks vm
- Has thanked: 8418 times
- Been thanked: 8162 times
Excellent images, Eric, as usual, even when the conditions are working against you.
Alexandra, James, Franco, Terry and Stu:
Much appreciated feedback.
Good day.
Good day.
