Seeing prominences with 5 nm H-alpha filter
- Jordan Konisky
- Has thanked: 386 times
- Been thanked: 270 times
Looking into purchasing a Astrodon 5nm Hydrogen-alpha filter. Would I be able to see solar prominences with this filter or do I need a more narrow band filter. Thanks.
Jordan -
Lunt CaK B1800 Filter Module
Lunt White Light Solar Wedge
Re: Seeing prominences with 5 nm H-alpha filter
Hello Jordan,
A quick web search has come-up with a possible answer, although whether it is accurate enough for you purposes is unknown to me.
https://stargazerslounge.com/topic/3256 ... re-images/
I hope you get a good result.
cheers
cheers
- JochenM
- Been thanked: 1619 times
That won't work I'm afraid.
Short version, the bandpass on that filter (eventhough it's considered quite narrow for night time use on nebulae etc); is way too wide for solar use. As a result, you'll end up with just an orange/red looking disk without any features to speak of.
- Has thanked: 57 times
- Been thanked: 1205 times
5nm to much
you need 1nm filter for proms you can get them from Andover optical
i have done that
2 ways
method one is the "thousand oaks" method where filter is placed in a tilt-tune holder and in a scope running at min f25 plus front ERF
method two is making an SPV(solar prom viewer) David Groski has instructions I have built 2 of them and it works well
it has occulting disk - it creates artificial eclipse
i have seen proms in Ha and Hb with this method and proper filter
i have done that
2 ways
here is pic I took with spv and 1nm Ha filter
that black disk is not done by software but actual occulting disk
method 1 (Hau) h alpha unit using skybender tilt device
- Has thanked: 103 times
- Been thanked: 207 times
The Astrodon is a night light pollution filter. You need a proper solar Ha telescope or solar Ha filter and blocking filter to mount on a refractor to see surface detail, including prominences
Solarscope SF70DS + TV85
TSA-120, Baader wedge
link to thousand oaks model
i dont think they sell them anymore
http://www.thousandoaksoptical.com/wp-c ... ctions.pdf
- Jordan Konisky
Thank you everyone for your constructive comments.
Jordan -
