November 29th - The Sun Awakens
- Been thanked: 4340 times
Hi everyone...
Well, I have to say that my session on Sunday (November 29th) was the best in the past few years since the Sun slipped in solar minimum. Not only were there 4 large AR's and a couple in development, but a phenomenal post flare loop prom on the SE limb. I see many manged to capture these features...congratulations to all for the successes!!!
I'll start with the full disk image series. First is the Ha image through the LS80T/DSII/B1800Ha solar scope and an ASI174mm camera: The WL and CaK images below were taken through the Stellarvue110 OTA and an ASI1600MM camera. The first is the WL image, though the Lunt Solar Wedge/Baader Continuum filter: followed by the CaK version through a modified Lunt Solar Wedge/B1800CaK/Baader K-Line filter set: As we could see in the full disk Ha image, the AR's 2785/2786/proto2789 cover an immense area in the southern hemisphere. The image below is a multi frame mosaic of these AR's taken through the modded CR-150/DSII/B1800Ha + 2.7x tele-centric + ASI174MM camera. From the Eastern limb, moving west across the disk we have AR2789, 2786, 2788, and 2785: AR2787 was starting its trek across the disk after recently rotating into view on the NE limb: It looks like I missed AR273 on the SW limb...oops
So with all this activity on the disk, the large number of proms were icing on the cake. These images are through the same Modded CR-150 setup as used for the AR's. The most impressive prom in years has to the the large loop prom that was left after the solar flare earlier in the day. For reference, this image below was taken at 15:49UT: There were many other proms which would have looked pretty good if not for the post flare show off The remaining proms are shown as we move clockwise around the limb form the SE: After the Ha targets were finished, I went back to the Stellarvue 110 and added a 5x Powermate to get higher resolution images of the big AR's in WL and CaK. The WL image is below: The last images of the session were with the 5x Powermate through the CaK filter set, but the seeing had become very poor as I approached the noon hour and most video clips were pretty much garbage...I should have used a 2x or 3x but was rushing. Below is the CaK image that I managed to get a little detail from: This is all the images I have for now...still processing a few of the big AR and the loop prom to see if I can make an animation...will post if they turn out
As always, questions and comments are always welcome,
- Has thanked: 9145 times
- Been thanked: 6025 times
Re: November 29th - The Sun Awakens
A really productive session, Brian. Everything looks great: I particularly like all the work you did with the proms, that came out really well, delicate and with great detail.
Thanks Franco...really appreciate your comments on the images
- Been thanked: 16694 times
Brian,
Absolutely stunning work on all accounts. You have captured those post flare coronal loop prominences very well. I still am upset because I missed them due to clouds. I got the alert on my phone concerning the flare. But alas. No clear sky. But thanks to You, Phil and Eric I have gotten stunning views! Thank You.
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
Wow - what a phenomenal record of the Sun - outstanding work! Post Flare Loops are one of my favourite features & your images of them pop. 10/10!
- Been thanked: 8791 times
What a fabulous set Brian I am so envious seeing the images with the post flare loops. I think I have only seen them once through the PST
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Fantastic Brian, great captures.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
James, Matt, Alexandra, and Stardust...
Your comments and feedback on this set of images are very much appreciated...thanks
Alexandra, the clouds that some members had on Sunday stole the show for many I hope that the weather gives you all in the UK a break and time to take in the AR's that we have now too!
- Has thanked: 103 times
- Been thanked: 207 times
That’s how I’m feeling Alexandra. It’s all well and good that Sun is active again, but not during a British winter.....
Great images Brian!
Solarscope SF70DS + TV85
TSA-120, Baader wedge
Thanks Mark !!!
Best wishes for clear skies...no good to keep the equipment inside when there is lots to observe.
- Been thanked: 4904 times
Brian:
Great session, like very much the prom shots.
Best regards.
Best regards.
Brian,
A very impressive set of images there, and a pleasure to view. Thanks
Phil
Phil
Eric and Phil...
Thanks fro your comments...always appreciated
- Has thanked: 6181 times
- Been thanked: 7142 times
That's a beautiful series, Brian!
Thanks for sharing!
best regards,
Arne
Thanks for sharing!
best regards,
Arne
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Wonderful image set. Love those proms Brian!
Dan
South central Indiana
USA
USA
Arnie and Dan...
Thanks for your comments on the session...very much appreciated
The majority of last weeks AR's were going around the western limb today, but a few more on the disk still make a great view!
- Has thanked: 20440 times
- Been thanked: 10246 times
Great set of images Brian, I missed these.
Thanks Mark!!!
- pedro
- Has thanked: 14 times
- Been thanked: 6577 times
A great session Brian, well done
Pedro Re'
