AR2786 | HA, CaK | Discs | Dec 1rst 2020
- Has thanked: 1171 times
- Been thanked: 1360 times
Chilly morning today in Florida, windy too, in the 30's F which is really cold for us. Seeing was decent. Transparency was good. But the wind was rather rough. AR2786 still has a gorgeous big spot and lots of wonderful mottling, fibrils and filaments around its area.
B&W:
Colored:
Seeing Conditions:
Equipment:
120mm F10 refractor
Baader Red CCD-IR Block (internal D-ERF) + PST Etalon + 10mm BF + ASI290MM
Baader Blue CCD-IR Block (internal D-ERF) + Lunt B1200 CaK + ASI290MM
ST80 + SM60/Lunt CaK/Baader Continuum + IMX183 for discs
B&W:
Colored:
Seeing Conditions:
Equipment:
120mm F10 refractor
- Has thanked: 20434 times
- Been thanked: 10243 times
Re: AR2786 | HA, CaK | Discs | Dec 1rst 2020
A very good set of images indeed Marty. You would have got away with the 8" for Ha first thing looking at the seeing chart. Long may your good seeing prevail!
Thanks Mark,marktownley wrote: ↑Tue Dec 01, 2020 6:08 pm A very good set of images indeed Marty. You would have got away with the 8" for Ha first thing looking at the seeing chart. Long may your good seeing prevail!
I was thinking of attempting to use the 8" early setup, but that seeing measurement is only 30 minutes long or so. My seeing went from 0.8" to 1.8~2" in just 30 minutes, sustained. I wish I had a mount capable of holding both my 8" and my 6" frac so that I wouldn't have to swap out scopes, losing some time of my only moments of good sub-arc seeing which lasts minutes in the morning. I have more time in the summer, but in the winter it's a much shorter window. But a new mount just to gain that convenience and bit of time would be over $3k USD, closer to $4k ultimately (CEM60, CGX-L, HDX-110/EQ8) after mounting and counter weights. Sigh! When I think I want to attempt CaK, I leave the SCT off too, simply because it's rotten in near UV anyways, refractors are the best multi-purpose scopes for this after all.
- Has thanked: 9144 times
- Been thanked: 6025 times
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- Has thanked: 9401 times
- Been thanked: 5568 times
Hi Marty,
Excellent images
Excellent images
Great set of images, Marty. CaK is showing quite a lot of details today. Nicely done.
- Been thanked: 4904 times
Marty:
A beautiful session with beautiful images.
Best wishes.
Best wishes.
- Has thanked: 2412 times
- Been thanked: 4786 times
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
Great collection of close-ups and FD in different wavelengths!
Thanks for sharing, Marty!
Arne
Arne
- Been thanked: 6576 times
Fantastic images Marty
- Lowjiber
- Has thanked: 238 times
- Been thanked: 109 times
Excellent set of images, Marty. Love the details. Thanks for the shares.
Clear Skies
Clear Skies
John
Lunt 60 PT B/1200, Quark-Chromosphere, and ZWO ASI120MM & ASI174MM Cams.
- Has thanked: 1304 times
- Been thanked: 63 times
Very impressive set of images, especially like the hires CAK.
John
John
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely Marty. Great capture's.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
Excellent work again, Marty.
Nice detail in those CaK plages!
