Post
by MapleRidge » Sun Jan 03, 2021 1:48 pm
Good day everyone...
A clear day here on Saturday and no rush to go anywhere allowed me to image and experiment with scope/filter combinations. As usual, the winter seeing was poor to start and terrible by the noon hour, but the shorter focal lengths involved for the full disk images was a bit forgiving. The AR's were almost around the western limb and only a few small proms were visible, but the filaments were the most prominent feature of the day
This first set of images are the full disks. The WL and CaK images were taken through the iStar 150mm, f8 OTA with the ASI1600MM camera. The WL image used a Lunt Solar Wedge/Baader Continuum filter set:
- IS__WL_10_45_55-IMP.jpg (899.14 KiB) Viewed 361 times
The WL wedge was swapped out for the modded Solar Wedge/B1800CaK/Baader K-Line filer set for the CaK image:
- IS__CaKK_10_54_10-ASI.jpg (834.7 KiB) Viewed 361 times
The next set of Ha images were through the LS80T and several DS options I have. The first image is the limb (inverted) with the disk blocked out...as mentioned there were few proms:
- LS80T_LS75FHa_10_00_53.jpg (157.69 KiB) Viewed 361 times
So the first DS image used the LS80T and front mount LS75FHa tilt etalon (used for the image above too):
- LS80T_LS75FHa_09_59_40-ASI.jpg (351 KiB) Viewed 361 times
The second DS setup was with the DSII pressure tuned module added and the front mount etalon removed. The tuning could have been a bit better but I gave up after messing with it for 15 mins or so
- LS80T_DSII_10_30_45-ASI.jpg (415.85 KiB) Viewed 361 times
The last image is a triple stack with both DS etalons...the DSII and the front tilt etalon:
- LS80T_TS_Ha_10_18_27-ASI.jpg (264.8 KiB) Viewed 361 times
So here's my questions...of the three options which would you keep setup for the full disk images ?
The last image is a colourized version of the triple stack:
- LS80T_TS_Ha_10_18_27-ASI-FC.jpg (313.87 KiB) Viewed 361 times
I will have more images to add once I get the processing finished on the Ha set through the iStar OTA.
Thanks,
MapleRidge on Sun Jan 03, 2021 4:52 pm, edited 1 time in total.
Photos:
https://www.flickr.com/photos/185395281@N08/albums
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
8' Diameter Dome
MI250 Mount carrying:
iStar 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
