18-01-2021 NEW AR's
EGRAY_OBSERVATORY
Been thanked: 4900 times
18-01-2021 NEW AR's
Post by EGRAY_OBSERVATORY »
With the S.E. AR showing what is an almost double-spot in one, there is another small AR in the N.E. approaching the limb in around 3-days time.
The Heliograph image shows the latest.
Cheers and CLEAR SKIES...
18-01-2021 0935z euvi_195_heliographic.jpg (46.84 KiB) Viewed 377 times
Has thanked: 20745 times
Been thanked: 10439 times
Re: 18-01-2021 NEW AR's
Thanks Terry, looks like a couple of spots in the region rounding the limb.
Has thanked: 17925 times
Been thanked: 8893 times
Looking good!! (but not the weather :( )
EGRAY_OBSERVATORY
Thanks Mark and Alexandra. Shortly after my posting of this post, I ended up in hospital for a short stay, with a confirmed visual-problem - which is now requiring a considerable-amount of treatment over the next six -weeks, probably requiring surgery after. In the mean-time I expect to have further difficulties in some seeing on the PC etc., so please bear with me if I miss or mistook something.
Having just looked at STEREO and SDO, I note a second spot area in the S.E. and will post images in a couple of minutes...
Has thanked: 17813 times
Been thanked: 16951 times
Post by DeepSolar64 »
EGRAY_OBSERVATORY wrote: Mon Jan 18, 2021 11:01 pm Thanks Mark and Alexandra. Shortly after my posting of this post, I ended up in hospital for a short stay, with a confirmed visual-problem - which is now requiring a considerable-amount of treatment over the next six -weeks, probably requiring surgery after. In the mean-time I expect to have further difficulties in some seeing on the PC etc., so please bear with me if I miss or mistook something.
Sorry about that Terry. It sounds serious. A fellow I worked with had to have surgery for macular degeneration. It's a issue with the retina if I remember right. I hope it's not that. It can be really serious. I will remember you in my prayers.
Blessings
James.
marios i.
Has thanked: 1707 times
Been thanked: 1125 times
Post by marios i. »
Nice!
Marios S.Ioannou
Sketcher/Visual Observer
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Thanks, Terry.
Good luck with everything.
EGRAY_OBSERVATORY
Thank you so much for your thoughts and replies - everyone.
James, it's not the problem that you mentioned, rather is "Acute Anterior Uveitis" and is currently under a 2-hour treatment regime, which will continue for six-weeks albeit with better treatment-times later...
At present, it is difficult for me even to read from the pc-screen, as is like looking through a fog, so I have to magnify the screen to help.
Yes Alexandra - you are in a storm-warning area, so hopefully you do not get too big a soaking.
The latest images will appear shortly in today's post 19-1.
CLEAR SKIES
Been thanked: 4957 times
Post by eroel »
Terry, hope that you get well soon.
Best wishes.
Get well soon Terry
EGRAY_OBSERVATORY
Thanks Eric and Mark. After the 6-week current treatment, it is likely that two Cataract operations will be necessary, so how long before getting back to normal is not yet certain, but hopefully soon.
I hope that the current/due stormy-weather doesn't cause any damage to yourselves over here in the U.K., as it certainly looks to be a problem
CLEAR SKIES AND KEEP DRY
EGRAY_OBSERVATORY wrote: Tue Jan 19, 2021 7:04 pm It is likely that two Cataract operations will be necessary
You will have bionic eyes Terry, you should check out your cak scope visually, you will see all sorts after the op.
EGRAY_OBSERVATORY
HaHa Mark, I could already see the "hue of blue" through the Cak scope with the Mk1 Eyeball, so if I could see more - that would be helpful, but whether that view could be worse - is another matter !!!
It'll certainly be interesting as to what difference the Cataract op will make changes and I will no doubt post the answer here, but if it is a good answer, will many of us go for the op - regardless ??
You'll have a Mk II eyeball after the op :lol:
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Post by JochenM »
Hope you make a swift recovery, Terry. Will be as good as new! ;)
Jochen Maes
Belgium
https://www.jochenmaes.com
EGRAY_OBSERVATORY
Thanks Mark, Mk2 eyeballs eh..
Thanks Jochen and certainly would look forward to the future...
Regards
Bionic Terry
