Literally, just a quadrant today as I had only a few minutes in the gaps between cloud banks, which were dropping snow on and off all morning.
Very little snow stuck around, but the ground was a bit slushy and wet making for a bit of a miserable session, but then it IS winter.....
So here are the images, or rather here is the image, just processed in different ways.
125mm Tecnosky with modified B1800 Lunt CaK module.
Basler acA2440-75um.
20210123_CaK by Stuart Green, on Flickr
20210123_CaK_colour by Stuart Green, on Flickr
20210123_CaK_Inverted_Colour by Stuart Green, on Flickr
Thanks for looking.
A bit of calcium Sun 23rd Jan '21
- Has thanked: 8418 times
- Been thanked: 8164 times
- Has thanked: 9417 times
- Been thanked: 5582 times
Re: A bit of calcium Sun 23rd Jan '21
Hi Stu,
Excellent images
Excellent images
- Been thanked: 10248 times
Looks good Stu, I was out earlier too. Its nice to be able to image in between the snow
- Been thanked: 8792 times
I like the colours I'm glad you were able to get some gaps and get a quadrant, it shows the main attractions nothing but constant line of snow coming from the Isle of Man here.
- Been thanked: 4904 times
Stu:
Very nice CaK images, wanted to take a look but at home is clouded now.
Best wishes.
Best wishes.
Very well done Stu and the colouring is fab and clearly defines the Cak colouring...
Thanks vm
Thanks vm
- Has thanked: 9145 times
- Been thanked: 6025 times
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Brilliant Stu, you did well between the clouds today. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Many thanks, everyone. Much appreciated.
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Thank you Stuart. Wonderful result
Marios S.Ioannou
Sketcher/Visual Observer
