Monday Sun Jan 25th 2021
- Has thanked: 8418 times
- Been thanked: 8162 times
I awoke to a scattering of snow this morning and the promise of sunshine from around 10:00am onwards, so I walked the dog, had breakfast and after a little wait to allow the Sun to clear my neighbour's rooftop, I got set up for a great morning session on the scopes.
FDs in all three lights and a few close views in Ha and Ca II K were all possible with almost cloud-free skies, which makes a really nice change as more often than not I'm chasing the cloud gaps.
Here's a SS Ha FD using my Lunt front etalon on a 72mm f6 fitted with a X2.5 PM/ Coronado BF15 and Basler acA1920-155um camera. Imaged as a 3 pane mosaic (could have been two, but I added a middle pane for good measure).
20210125_Ha_FD_Mono by Stuart Green, on Flickr
20210125_Ha_FD_SS_Colour by Stuart Green, on Flickr
Switching over to the opposite side of the spectrum, now using a Tecnosky 125 mm f/7.8 with a modified Lunt B1800 Ca II K module and Basler 2440-75um, here's a full disk in ionised calcium. These are 4 pane mosaics.
20210125_CaK_FD_Mono by Stuart Green, on Flickr
20210125_CaK_FD_Colour by Stuart Green, on Flickr
Using the same scope and camera, I switched out the Lunt module for a Lacerta WL wedge fitted with a 540nm continuum filter and a couple of polarisers to knock down the image brightness. Again, imaged and processed as 4 pane mosaics. The sunspots look teeny weeny in these images. Just large pores, really.
20210125_WL_FD_Mono by Stuart Green, on Flickr
20210125_WL_FD_colour by Stuart Green, on Flickr
The seeing conditions weren't too bad so I decided to try some higher magnification shots of the active regions in Ha and Ca K.
Here's the Ha version of AR2797 on my 150mm modified DS Lunt 35, imaged as a series of panes to capture the whole active region using a X2.5 PM and Basler acA1920-155um
20210125_Ha_AR_Mosaic by Stuart Green, on Flickr
This image includes the darkening effect observed closer to the limb.
In these images I've flattened out the gradient.
20210125_Ha_AR2797_Mono by Stuart Green, on Flickr
and added colour...
20210125_Ha_AR2797_Colour by Stuart Green, on Flickr
Here's part of the same region in Ca II K captured on the Tecnosky 125 mm now with a x2.5 PM and the Basler acA2440-75um.
20210125_CaK_AR2797_Mono by Stuart Green, on Flickr
20210125_CaK_AR2797_colour by Stuart Green, on Flickr
I think I was pushing my luck with these at this time of the year and they may be a little over processed, but hey.....
Anyhow, thanks for looking.
and added colour...
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Re: Monday Sun Jan 25th 2021
Beautiful images Stuart.
Marios S.Ioannou
Sketcher/Visual Observer
- Has thanked: 20435 times
- Been thanked: 10245 times
These are really impressive Stu! I think my favourite is the SS Ha FD, really nice! You sure you're still wanting to sell this? Seeing that disk has my wallet twitching...
- rcwinter
- Has thanked: 191 times
- Been thanked: 265 times
Brilliant, lovely images indeed, I failed yesterday to get focus, seeing was awful
Baader DERF 90 & 160. Vixen SP102M Moonlite, Takahashi TOA130 Feathertouch 3.5, Takahashi FSQ106N, Daystar Quantum SE .4ang, Apollo Max, ZWO ASI 174MM. 2600mm, 178MM, Lumenera Skynx & Infinity 2
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely, thanks for sharing, I was chasing gap's in the clouds today so only managed a little ha.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 17667 times
- Been thanked: 8789 times
Wow!! this is quite a collection for a cold winter day my favourites are the CaK s
Many thanks, everyone. It’s nice to see the Sun getting a little higher as the weeks go by.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- Been thanked: 4904 times
Great high res images include CaK !
Thanks vm Stu for your impressive collection of images and my fav are the Cak's.
Well done
Well done
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
Hi Stuart,
That is an awesome harvest! Interesting to see the images produced by Basler acA2440-75um. Any insights on it for high-res imaging?
Alfred
Alfred
Really excellent Stu. All good but I've missed your hi-res images the most. Thanks
Phil
Phil
Many thanks, everyone. I really appreciate your comments and feedback.
Hi Alfred,
Many thanks for your comments.
Regarding the camera, the small pixel size (3.45um) will mean the images are over-sampled at high focal ratios (for high magnification views), but the main issue I've found with H-alpha is the generation of Newton's rings. Tilting helps, but it can still be a challenge.
- Has thanked: 9144 times
- Been thanked: 6025 times
- Been thanked: 16694 times
Stu
I love all three lights but I think the CaK ones are my favorites. All are beautiful images!
Stuart and all. Here's an interesting comparison between your CaK image and the SDO 1600 image. The detail they show is very close. The main difference is the color used in processing! The SDO image may be just a wee bit sharper but again little difference. Very well done Stu!!
Where exactly does the SDO image lie on the solar spectrum?
- Has thanked: 6181 times
- Been thanked: 7142 times
A wonderful collection of images in different wavelengths, Stu! Love them all!!
Arne
Arne
yes, they're very similar. The SDO image you posted is 160 angstroms, CaK would be 3933angstroms - I think!DeepSolar64 wrote: ↑Tue Jan 26, 2021 4:21 pm Stuart and all. Here's an interesting comparison between your CaK image and the SDO 1600 image. The detail they show is very close. The main difference is the color used in processing! The SDO image may be just a wee bit sharper but again little difference. Very well done Stu!!
Wait till the sun is higher in the sky. we'll play a game of 'get better images than NASA' Multi million dollar satellite versus bloke with a scope in his back yard. We win on here more often than not
Ha...good one, Mark. On the whole I do think between all of us we do a pretty good job
James,
The SDO image is 1600 Angstroms, so well into the UV. I understand the image is from the transition region in the upper Chromosphere and the absorption line comes from carbon IV. There's quite a bit about this on the internet.
James,
That's good! It is surprising how good we do compete with the pros!! We often exceed GONG and compete well against the SDO.Wait till the sun is higher in the sky. we'll play a game of 'get better images than NASA' Multi million dollar satellite versus bloke with a scope in his back yard. We win on here more often than not
How does nanometers compare with angstroms? Related? Same? Similar?
Aha! I understand now!
WoW, and it tells me how narrow a bandpass our Ha etalons really are. I am still learning some of the finer points of solar tech.
That's a well-good sentiment Mark, so why not approach NASA and suggest that they could save so much dosh and get better images via SolarChat.
THEN ask NASA how much they would pay the SolarChat website and its' members for the privilege ???
AT least it would save zillions of dollars/pounds to NASA., albeit it could then make us amateurs then professionals and would likely then need us/SolarChat - declare the earnings to the relevant-governments for taxation purposes, so perhaps we should stay as amateurs... Simples...!!
I will second that Terry. I could then get my computer and go beyond visual or at least add to it. It would be nice to make solar observing my job!!
