Sun in H-Alpha 31th of January 2021
- Has thanked: 6181 times
- Been thanked: 7142 times
Cold and clear today also. The Sun however is rather quiet! In this image I have tried to push the shadows a bit more to make the prominences more visible.
Stack of the best 60% (1650 of 2751) images captured with an exposure time of 29ms and 30fps. Stacking done in Autostakkert 3, sharpening in AstraImage and contrast stretching in Adobe PhotoShop.
Arne
Equipment used for this image was a Coronado SolarMax 60 II w/BF15 filter, Baader 35nm H-Alpha filter and ASI ZWO 178MM camera. Everything mounted on a Sky-Watcher SolarQuest mount.Stack of the best 60% (1650 of 2751) images captured with an exposure time of 29ms and 30fps. Stacking done in Autostakkert 3, sharpening in AstraImage and contrast stretching in Adobe PhotoShop.
Arne
Re: Sun in H-Alpha 31th of January 2021
Well Arne, that is a great improvement for a day when there has been as little happening for quite some time on the disk and/or proms..
Very well done, and especially with the low-down Sun and this time of the years' weather too.
- Has thanked: 9417 times
- Been thanked: 5583 times
Hi Arne,
Well done. For what do you have an additional 35nm H-alpha filter in your optical train ?
- Has thanked: 17581 times
- Been thanked: 16697 times
I wondered that too.
It's nice to see images through a scope I use a lot visually.
- Been thanked: 10248 times
Good disk Arne, the sun is quiet!
- Been thanked: 4340 times
Great shot Arne!!!
- Been thanked: 4904 times
- Has thanked: 9145 times
- Been thanked: 6026 times
- Been thanked: 8793 times
Wonderful!! even on a day with not many proms you have picked them out
Thank you all!
I’m using the 35nm H-Alpha filter as an UV/IR-blocking filter. It reduces any off-band light leakage and makes the disc more uniform with more contrast as well as reducing reflections around the Sun.
Here’s a comparison I did with the same telescope (Coronado SolarMax 60 II w/BF15 filter) together with a Cemax 2x barlow and an ASI ZWO 1600MM Pro camera back in November
Without any extra filter: With 35nm H-Alpha filter: Both images were shot using the same gain and with a neutral gamma setting. Only the exposure time was adjusted to achieve the same max value (approx. 200). For the image without any extra filter that meant an exposure time of 49ms while exposure time had to be increased to 109ms to reach the same level with the 35nm H-Alpha filter. This really illustrates how much light outside this 35nm area is leaking through without the filter.
Both images where sharpened in Astra Image using the same settings. No further processing
Arne
Arne
It makes a difference! I wonder if it would make a difference visually?
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Thanks for sharing Arne, I'm all clouds here for the last couple of days and the forecast isn't good for me either.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
That's quite a difference Arne! Are you using the original blocking filter that came with the scope?
Hi, Mark.
Yes, I'm using the BF15 filter that came with the scope. I have another BF15 filter that came with my SolarMax90, but I haven't had the chance to do any comparison between the two. That'll have to wait until it gets a bit warmer.
Arne
Arne
An incredible difference between the two setups!!!
Thanks for showing these.
Obviously passing some extra IR light which the camera is picking up, you won't see this with your eye as it can't see this wavelength. Both Bob and I had exactly the same problem with the Solarscopes. Visually great by eye, but camera picked up the IR. Corrected by an extra blocking filter. Your 35nm filter is doing exactly the same job.
Hi Arne,arnedanielsen wrote: ↑Mon Feb 01, 2021 10:13 pm Thank you all!
Arne
Thank you for the explanation. One more question: Are you 100% in the best etalon adjustment e.g in band ?
Thanks Rainer
Indeed. My 2 coronado bf15s use quite different ITF filters and one 'works' with my SM90, one does not (same thing as Arnes image). These are stock blocking filters too, not mods.Montana wrote: ↑Tue Feb 02, 2021 4:18 pm Obviously passing some extra IR light which the camera is picking up, you won't see this with your eye as it can't see this wavelength. Both Bob and I had exactly the same problem with the Solarscopes. Visually great by eye, but camera picked up the IR. Corrected by an extra blocking filter. Your 35nm filter is doing exactly the same job.
- Has thanked: 8418 times
- Been thanked: 8165 times
Nice FDs.
Just an observation and comment if I may? 109ms is really slow. I'd be expecting at least 10-20 ms, which is what I get with my Lunt 60 double stacked (so I'd expect yours to be similar at least). The issue for you with such a slow speed (at over 1/10th second) will be the setup's sensitivity to the seeing conditions. Are you sure it is 109ms and not 10.9 ms (and also 4.9 ms rather than 49 ms)?
Maybe it's due to the low winter Norwegian Sun
- Has thanked: 103 times
- Been thanked: 207 times
A very illuminating thread.marktownley wrote: ↑Tue Feb 02, 2021 6:47 pmIndeed. My 2 coronado bf15s use quite different ITF filters and one 'works' with my SM90, one does not (same thing as Arnes image). These are stock blocking filters too, not mods.Montana wrote: ↑Tue Feb 02, 2021 4:18 pm Obviously passing some extra IR light which the camera is picking up, you won't see this with your eye as it can't see this wavelength. Both Bob and I had exactly the same problem with the Solarscopes. Visually great by eye, but camera picked up the IR. Corrected by an extra blocking filter. Your 35nm filter is doing exactly the same job.
Mark - did Coronado change its ITF filters at some stage or did you make the change yourself to one of your stock BF15s?
Solarscope SF70DS + TV85
TSA-120, Baader wedge
Something changed, and (for once!) it wasn't me who changed itHighbury Mark wrote: ↑Tue Feb 02, 2021 8:21 pm A very illuminating thread.
Good point Stu.Carbon60 wrote: ↑Tue Feb 02, 2021 8:07 pm Nice FDs.
Or a rusted / degraded ITF? When was the last time you checked it Arne?
That's my conclusion as well.Montana wrote: ↑Tue Feb 02, 2021 4:18 pm Obviously passing some extra IR light which the camera is picking up, you won't see this with your eye as it can't see this wavelength. Both Bob and I had exactly the same problem with the Solarscopes. Visually great by eye, but camera picked up the IR. Corrected by an extra blocking filter. Your 35nm filter is doing exactly the same job.
Arne
Hi Rainer,
I can't say that I’m absolutely 100% sure, but I think it’s close to as good as it gets with this scope.
Arne
Hi Stu,Carbon60 wrote: ↑Tue Feb 02, 2021 8:07 pm Nice FDs.
Yes, 109ms is indeed slow and as you say it makes it very vulnerable to poor seeing. The exposure time is correct however (also verified by the drop from 17fps for the 49ms exposure to 9fps for the 109ms exposure). I think the long exposure can be explained by the sum of the following factors:
• Low altitude of the Sun
• Using the 2x CeMax to for doubling the focallength and increasing the f/number to 13.3
• The small 3.8µm pixel size of the 1600MM Pro.
• Gain setting of 140
The good thing is that with only 60mm of aperture the resolution is rather limited (approx. 1,93” according to Dawes limit) so it’s not that sensitive to poor seeing.
Arne
Hi Mark,marktownley wrote: ↑Tue Feb 02, 2021 8:26 pm Good point Stu.
I bought the SolarMax 60 II second-hand last Autumn. It looked ok when I inspected it then, but I should maybe do a more thorough check.
I will also try to testing the to BF15 filters against each others, but that will have to wait until the days get longer and the weather gets warmer.
Arne
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Wonderful result
Marios S.Ioannou
Sketcher/Visual Observer
