4 days of Sun and here the discs
In H-alpha some more filaments visible in the southern hemisphere as well as a small plague on the limb. ¿ Will a spot develop ?
In White Light some plagues visible as well on the southeastern limb but no hints of a spot.
Full disk 07-02-2021
- Has thanked: 9401 times
- Been thanked: 5561 times
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: Full disk 07-02-2021
Nice captures Rainer, least you're getting more sun than me, lol.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 16691 times
Rainer,
It's amazing how the Sun changes even over the course of a few hours as seen and imaged from observer to observer. I can see changes/differences in the features between GONG Cerro Tololo, My visual observations, Nigella's images and your images. We all see many of the same details but there are also a fair amount of differences too between what each of us see/image. Part if it may be method or technique but The Sun sure is a fickle critter! Always in a state of change.
Great job as usual!!
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Well done yet again Rainer. I was hoping that SE area would have a sunspot.
Dan
South central Indiana
USA
USA
Hi Rainer,
I'm hazarding a guess that the new AR on the S.E.Limb border will or should have a spot or two as clearly prominences would normally dictates, but of course whether they and the AR last long-enough during its' transit across the face - is another matter...
I do hope so, as might allow me to do a capture in one or more of the three-lights from here...
There may also be an approaching AR in the N.E. approaches to the limb, but too early to confirm that as yet...
Thanks for you posting
Me too!!
- Been thanked: 4340 times
Very sharp FD images Rainer...well done
- Has thanked: 20424 times
- Been thanked: 10243 times
Looks really good Rainer!
