February 8 2021 Observations
Has thanked: 17813 times
Been thanked: 16953 times
Post by DeepSolar64 »
Session time is 10:30am until 11:36am EST local time. Skies are partly to mostly cloudy. Seeing is average to maybe a bit below average. The temperature is 39F.
Coronado SolarMax II 90 DS. 32x, 44.5x and 64x ( Ha )
I can easily see two filaments is DS. One just to the east of south-center looks double at first but a thin fainter part connects them. To the NE lies another easy filament. I also pick up a tiny filament SW of the double-bar filament. I am actually not sure whether it's truly a filament or a more prominent spicule cluster ( mottle ).
There is a wonderfully bright large prominence on the SE limb. To me it looks like an animal's head complete with a mouth, ears/horns and a dark eye. I also see another group on the opposite limb ( NW limb ) of the big prom. I can also see a few other small/fainter ones around the limb. I can see the thin spicule layer on the limb too.
The plage to a new AR in the SE is easily seen north of the big animal prom.
The mottles are visible without difficulty.
Celestron NexStar 102GT w/Atlair wedge and 540nm filter. 55x and 100x ( WL )
I can easily pick out the faculae of the new AR near the SE limb. I can also see two tiny pores within it! Otherwise only the fine granulation is visible but soft.
Carpe Diem!
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Re: February 8 2021 Observations
Post by Stardust5858 »
Thanks James, I've read reports elsewhere of the new AR having a spot.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Thanks James for your report.
Nigella has mentioned about the S.E. AR having a spot - from reports. I have now acquired the latest SDO images and studied that area in the various lights and can see no sign of a spot as the latest attached SDO image shows.
I feel that judging by the proms previously coming from this area (prior to being over the horizon) that any proms have since disappeared - for now at least...
Without STEREO-B being operational, a certain amount of guess-work has to be assumed.
8-2-2021 1623z latest_512_HMII.jpg (28.48 KiB) Viewed 230 times
EGRAY_OBSERVATORY wrote: Mon Feb 08, 2021 5:19 pm Thanks James for your report.
Terry,
I just pulled these from the web. They are just a bit more current than the one I posted from my report. Should be current to now.
Screenshot from 2021-02-08 12-22-39.png (112.51 KiB) Viewed 228 times
EGRAY_OBSERVATORY
Ok James on that and certainly that does look like spots in that image and assuming the time of 12:22:39 of GMT/UTC/Z time could well account for the fact that SDO was down from the internet at that time - where i could not post a similar image...
Do we know where the image originated from ??
Thanks vm for the update
EGRAY_OBSERVATORY
https://www.spaceweatherlive.com/en/solar-activity.html
is showing the small spots in that AR as the attached image of 16:45z shows.
8-2-2021 1645z SDO_HMIIF_1024.jpg (105.09 KiB) Viewed 221 times
They are really small as the image shows. We need em' to grow!
EGRAY_OBSERVATORY
Perhaps if we could water em, it might help...
:lol: :lol: :lol: :cool:
Has thanked: 20757 times
Been thanked: 10442 times
Nice report, thanks James!
You are welcome Mark. Hopefully tomorrow I can do it again.
Has thanked: 8523 times
Been thanked: 8259 times
Post by Carbon60 »
Thanks, James.
