2021-02-09 - A prominence in the snow
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Post by JochenM »
-10 degrees (Celsius) and a good bit of snow on the ground here today; but a nice and clear sky. Glad I made the choice to have my setup be remote-controllable (if that's even a word) a while back; so nice and cozy in my office with some tea :)
I was expecting conditions to be challenging, but after waiting for about 30 minutes and seeing nothing but mush on the screen; I figured something else must be going on. Then it occured to me that the Quark I'm using is relying on heat in order to get on band. Even though the green light was on; I suspected this might the culprit. A quick bit of tinkering to give it a thermal jacket (one of those things to keep a drinking container warm/cold and a bit of tape) and 10 minutes later everything was fine.
Seeing was quite bad, but tried to make the most of it (using the fleeting moments of acceptable seeing to get some quick captures in). There's quite a sizeable tower prom on the South Eastern limb; so that become the obvious target of attention.
Setup: 80ED, Quark Chromosphere, Baader 35nm H-Alpha filter, IMX174.
Thanks for looking!
ImageProminence - 2021-02-09 by Jochen Maes, on Flickr
Jochen Maes
Belgium
https://www.jochenmaes.com
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: 2021-02-09 - A prominence in the snow
Post by EGRAY_OBSERVATORY »
Two excellent images Jochen.
-10 degs C eh !! And it's coming our way, so thanks for the that...
Lots of detail and thanks for sharing
p.s. You shouldn't have mentioned the snow, as somebody wants that more than you... !
Alto
Has thanked: 962 times
Been thanked: 333 times
Post by Alto »
What a gem! Thanks for reminding us it still exists! These east winds of late have been very cloudy!
Call me Geoff.
JochenM
Post by JochenM »
Cheers fellas.
Sorry, Terry :D
Jochen Maes
Belgium
dhkaiser
Has thanked: 1407 times
Been thanked: 899 times
Post by dhkaiser »
Cool prom image.
Dan
South central Indiana
USA
rsfoto
Has thanked: 9690 times
Been thanked: 5758 times
Post by rsfoto »
Very well done.
Has thanked: 17813 times
Been thanked: 16951 times
Post by DeepSolar64 »
Very nice! I just observed it visually.
Has thanked: 20743 times
Been thanked: 10439 times
That's a good shot Jochen in challenging conditions. These quarks are sensitive (understandably to be fair!) to extreme conditions. Think I would need a warm jacket on in that weather too :lol:
JochenM
Post by JochenM »
Thanks all.
Indeed, Mark. I don't think "lets put it in the snow and see what happens" is part of the manufacturer's testing procedure :D
Jochen Maes
Belgium
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Post by Stardust5858 »
Brilliant capture, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
And observing at 14F. That's cold! A warm remote site inside was smart! Still you had to go outside and wrap the Quark up.
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Nice images, Jochen. Now that IS cold.
JochenM
Post by JochenM »
Thanks all.
James, I wanted to have the option to not have to be out in the elements when it's not all that pleasant. Even when dressing for it; sitting still at the telescope, it gets a bit much. And I'm sure I'll be glad I did it during the worst of the summer heat as well.
Still planning to get my dose of vitamin D whenever it's more enjoyable though. :)
Jochen Maes
Belgium
Has thanked: 9294 times
Been thanked: 6129 times
Post by ffellah »
A very good result on a freezing day, Jochen. The prom looks great.
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Hi Jochen...
Very nice image of the prom, with lots of fine detail...well done :bow
It looks like your session was about the same as mine yesterday as far as temperature goes.
JochenM
Post by JochenM »
Thanks Franco/Brian.
Jochen Maes
Belgium
