Another sunny day and finally some activity on the Sun again. A small "proto-sunspot" and some nice protuberances.
A slightly higher solar elevation allowed me to reduce the exposure time from 29ms (used on January 31st) down to 24ms keeping all the other settings the same.
Equipment used for this image was a Coronado SolarMax 60 II w/BF15 filter, Baader 35nm H-Alpha filter and ASI ZWO 178MM camera. Everything mounted on a Sky-Watcher SolarQuest mount.
Stack of the best 60% (1650 of 2751) images captured with an exposure time of 24ms and 30fps. Stacking done in Autostakkert 3, sharpening in AstraImage and contrast stretching in Adobe PhotoShop.
Arne
Sun in H-Alpha 10th of February 2021
- arnedanielsen
- Has thanked: 6305 times
- Been thanked: 7323 times
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: Sun in H-Alpha 10th of February 2021
Lovely you got some data, clouds here yet again. I seem to go day's/weeks of cloud before I can see the sun again. Still, as you say the sun is getting higher in the sky which is great. Thanks for sharing Arne.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- Has thanked: 9723 times
- Been thanked: 5773 times
Hi Arne,
Well done.
Well done.
- Has thanked: 17849 times
- Been thanked: 16992 times
Nicely done. You got the plage and the proms!
- Has thanked: 20813 times
- Been thanked: 10485 times
Nice disk Arne!
