Dear all,
Here's todays catch.
Equipment used for this image was a Coronado SolarMax 60 II w/BF15 filter, Baader 35nm H-Alpha filter and ASI ZWO 178MM camera. Everything mounted on a Sky-Watcher SolarQuest mount.
Stack of the best 60% (1650 of 2751) images captured with an exposure time of 29ms and 30fps. Gain reduced to 130 (from 150 used in the previous days). Stacking done in Autostakkert 3, sharpening in AstraImage and contrast stretching in Adobe PhotoShop.
Arne
Sun in H-Alpha 13th of February 2021
- Has thanked: 6181 times
- Been thanked: 7142 times
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: Sun in H-Alpha 13th of February 2021
Thanks Arne, still some filaments and plage details. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4340 times
Look good Arne!!!
- Been thanked: 16689 times
It looks like the proms have waned down a bit.
Well done Arnie on some well-good images.
Thanks for sharing
Thanks for sharing
- Has thanked: 20424 times
- Been thanked: 10242 times
Came out well Arne!
- Has thanked: 17648 times
- Been thanked: 8787 times
A great full disc Arne, I'm glad you are getting some sunshine, none here
- Has thanked: 9143 times
- Been thanked: 6024 times
Thank you all!
Not much activity and the biggest PROM had faded and was very weak.
Arne
Arne
