Sun in H-Alpha 14th of February 2021
- Has thanked: 6305 times
- Been thanked: 7324 times
Todays image of the Sun from my Northern location. According to the weather-forecast this will be my last solar-image for at least one week ☹
Equipment used for this image was a Coronado SolarMax 60 II w/BF15 filter, Baader 35nm H-Alpha filter and ASI ZWO 178MM camera. Everything mounted on a Sky-Watcher SolarQuest mount.
Stack of the best 60% (1650 of 2751) images captured with an exposure time of 28ms, gain 130 and 30fps. Stacking done in Autostakkert 3, sharpening in AstraImage and contrast stretching in Adobe PhotoShop.
Arne
Arne
- Has thanked: 17853 times
- Been thanked: 16995 times
Re: Sun in H-Alpha 14th of February 2021
That Coronado SolarMax II 60 images well. Are you single stack or double stack?
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Thanks for sharing Arne, weather here is awful too.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- Been thanked: 4427 times
Hi Arne...
Your image is quite good, nice and sharply focused too!
I wonder if the tuning could be adjusted a bit...I'd expect to have more of the limited disk features captured, but maybe thsi is what the single stack can give.
Thanks Arne for your capture - showing some proms and not a lot on the disk.
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
Hi Arne,
That is a nice looking full disk!
The weather forecast for the week over here in Singapore is cloudy every day, except Sunday when rain is expected. I don't usually rely on the forecast. Most of my images are captured in cloudy and raining forecast
Alfred
Alfred
- Has thanked: 20817 times
- Been thanked: 10487 times
That came out well Arne, hope the sun returns soon for you!
- Has thanked: 8558 times
- Been thanked: 8290 times
Nicely done, Arne. Beautifully even across the disk.
- Has thanked: 9319 times
- Been thanked: 6157 times
Great shot Arne maybe you are getting our nasty weather now
Thank you all for your comments.
Brian: Both the camera and scope is quite new to me and I haven’t had the time to play to much with finetuning it. I will have to look more into that when the Sun gets higher and the temperatures a bit more pleasant. Even as a Norwegian I try to keep my imaging sessions short when the temperatures are -10 to -15C
Arne
Arne
