Belated FD image's from 21st
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Hi all, again a frustrating time. Image's from the 21st February. On the day my solarquest mount decided not to play ball and wouldn't lock on to the GPS satellites and wouldn't work. What normally takes a minute took an hour of switching the thing on and off. Next the clouds started to form and seeing wasn't so good. Anyway enough of that. Here are the results. Lunt 60mm DS and 80ed badder K-Line scope. Apologies for the time stamp on these. They should read 20210221. All processed today
- PSX_20210224_165647.jpg (912.35 KiB) Viewed 391 times
- PSX_20210224_165549.jpg (794.2 KiB) Viewed 391 times
- PSX_20210224_165526.jpg (245.41 KiB) Viewed 391 times
- PSX_20210224_165508.jpg (256.67 KiB) Viewed 391 times
- PSX_20210224_165455.jpg (127.37 KiB) Viewed 391 times
- PSX_20210224_165356.jpg (157.26 KiB) Viewed 391 times
- PSX_20210224_165320.jpg (209.01 KiB) Viewed 391 times
- PSX_20210224_165120.jpg (176.83 KiB) Viewed 391 times
- PSX_20210224_165048.jpg (346.63 KiB) Viewed 391 times
- PSX_20210224_165003.jpg (1.35 MiB) Viewed 391 times
- PSX_20210224_164839.jpg (1.02 MiB) Viewed 391 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- JochenM
- Been thanked: 1619 times
Re: Belated FD image's from 21st
You still managed to pull out some nice images (despite the seemingly difficult conditions). Looks good.
- Stardust5858
Thanks, appreciate the comments. Yeah, wasn't to bad after the frustration. Worth it in the end, lol.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 6181 times
- Been thanked: 7142 times
- Stardust5858
Thanks Arne, appreciated.arnedanielsen wrote: ↑Wed Feb 24, 2021 7:50 pm Good collection of images! Thanks for sharing!
Arne
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 20424 times
- Been thanked: 10243 times
Came out well given the challenges with equipment!
- Stardust5858
Thanks Mark, appreciate your comment. I guess we all get equipment challenge's from time to time, lol. I was using a few choice words, lol.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 8415 times
- Been thanked: 8161 times
Don’t you just hate those frustrating sessions? The images came out well in the end, though.
- Stardust5858
Thanks Stu, appreciate your comment. Yep, really frustrating when you hope to get some nice imaging done and things don't work for no reason whatsoever that worked last time you switched it off. As they say Stu, all's well that ends well.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Tweaked FD from the 21st.
- PSX_20210225_003527.jpg (1.56 MiB) Viewed 345 times
- PSX_20210225_000912.jpg (1.33 MiB) Viewed 345 times
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 16693 times
All are very nice images but that last one is absolutely stunning! I would be proud of that one!!
- Stardust5858
Thanks, really appreciate that. I like it a lot, lol. Clear here for the new few days so hopefully capture some more ray's.DeepSolar64 wrote: ↑Thu Feb 25, 2021 6:04 am All are very nice images but that last one is absolutely stunning! I would be proud of that one!!
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 9144 times
- Been thanked: 6025 times
- Stardust5858
Thanks Franco, very much appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 17667 times
- Been thanked: 8788 times
That's a pretty phenomenal filaprom and lots of super images
Sounds like me at lunchtime, not much time between clouds, mount wouldn't move in declination, left the Baader K line filter on and couldn't understand why the Halpha disc wasn't there, couldn't work out what was going on with the DS filter etc etc. These things are sent to try us when we have very limited time.
- Stardust5858
I guess it happens. Was imaging today and all went smoothly, can't believe or understood why these random glitches happen. Hope you got some data.Montana wrote: ↑Thu Feb 25, 2021 4:09 pm That's a pretty phenomenal filaprom and lots of super images
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
