February 25 2021 Observations. Solar CCT test and 430nm filter tryout.
- Has thanked: 17863 times
- Been thanked: 17007 times
Session time is 10:26am until 11:45am EST local time ( US ). The skies are clear with fair seeing. The temperature is 61F.
Coronado SolarMax II 60 DS. 16x and 21.5x ( Ha )
First off I notice two active region plages. AR12804 and AR12805. AR12804 is the easiest to see and I can see it's spots within. I can also see AR12803 to the east of AR12804 but it appears to be no more than a mere disturbance. AR12803 is just across the central longitudinal meridian heading into the NW quadrant behind AR12804. AR12805 is in the SW quadrant.
I can see a smattering of filaments in the SW quadrant NE, SW and SE of AR12805. Two are easy to see. I see one prominence on the NE limb.
The mottles are easily seen today.
Astro-Tech AT72EDII w/Altair wedge + 430nm and 540nm filters. 24x, 36x and 72x ( WL )
First off I tried out the Edmund 430nm filter. It's only the second time I have used it. Using it I can see the spots of AR12804 with one showing a visible penumbra. I can also see the granulation. The seeing still falls short of taking full advantage of this short wavelength filter. I can also see the spot of AR12805.
The Baader 540nm Continuum filter does much better. I can see the largest spot in AR12804 indeed does have a penumbra surrounding a ragged umbra. The second largest spot is elongated and also has a penumbra. To their east is a northward curving line of pores. I see one dark pore north of a line bettween the two largest spots. I can see most if not all the spots/pores the SDO continuum image shows in AR12804. I see one small spot in AR12805. I glimpse a tiny single pore in AR12803 though the SDO continuum image shows about 6 of the granule-sized objects. The granulation is visible and is easier than in the 430nm filter. I can hint at the faculae to AR12804.
Unfiltered white light does well too but overall I think the 540nm filter gives the best view.
CCT Test. Lightspectrum Pro on iPhone XR.
Today I decided to try an experiment. To take a Correlated Color Temperature of the solar disc. At work ( GE Current ) we use professional Konica Minolta CCT meters to test the color temperature of our LEDs to make sure they are in spec. I have a CCT meter app on my phone called LightSpectrum Pro that can measure color temperature. Unfortunately it is no where near as precise as the pro meters at work and I use it there only as a backup if our meters/testers there go out of use or fail to work. Unlike the professional ones this phone app cannot be calibrated for luminance so if an object is too bright or too dim it skews the results. But since I don't have one of our Minolta meters at home I thought I would try it. Using the phone app directly at the sun through the phone camera I got a range between 5100-5300 Kelvin. Then I tried it through the telescope. I chose the Orion70 because it has a more white image. The ND3 filter in the Altair wedge is a bit warmer and would skew the reading low. Using the Orion70 which was surprisingly difficult. I had trouble holding the phone still while centering the solar image in the app window at the right distance and then trying to do a screen capture. Annoying to say the least, I finally took the eyepiece out of the diagonal and used the light coming off the diagonal. That helped though getting the meter to settle down and give a constant reading was still difficult. I came up with 5679K. I think the solar color temperature is around 5750 from the ground if I remember correctly.
I won't swear by the accuracy of this but it was an attempt. An experiment.
And my adorable little cat who is always nearby when I observe came to sunbathe!
Carpe Diem!
Carpe Diem!
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
Re: February 25 2021 Observations. Solar CCT test and 430nm filter tryout.
Thanks for the report, James.
Interesting experiment. Result seems to be what you would expect indeed.
PS: your solar buddy seems to be enjoying the warm sunlight quite a bit there
I guess the experiment is a success. But it was not easy to do as it should have been.
Lily loves sunbathing. She's a fixture at the scopes!
- Has thanked: 20834 times
- Been thanked: 10502 times
Very good James, and an interesting experiment!
- krakatoa1883
- Has thanked: 153 times
Thanks for your detailed report, James (nice cat!).
- Been thanked: 4434 times
Good report and test today James
Lily would be making snow angels here
Thanks everyone. That little cat is a constant companion when I am doing solar work. But she is like a dog. Follows me everywhere. Comon Mark T. You have cats don't they tend you at the scopes?
Brian,
Both our cats aren't crazy about snow. Salem, our big black Maine Coon cat really shows up when he is out in it! Lily tolerates it better than he does.
Cats are such adorable creatures.
Brian,
They sit and watch me James sometimes. Mostly in the daytime sleeping is their main priority.
Ours do a lot of sleeping too. And eating!marktownley wrote: ↑Fri Feb 26, 2021 6:15 am They sit and watch me James sometimes. Mostly in the daytime sleeping is their main priority.
- Has thanked: 8559 times
- Been thanked: 8297 times
Interesting result, James. Close to the accepted temperature of the photosphere.
Thanks for your report. Lily has the right idea.
- Has thanked: 9327 times
- Been thanked: 6163 times
Thank you Stuart and Franco.
Smartphones can be useful tools in amateur solar research. I have used mine in imaging prominences, imaging white light and now taking the solar color temperature. All behind a telescope of course. I have also imaged the moon, M31 ( central region ) and Jupiter with it ( I got the 4 moons and two main belts! ) Though I haven’t tried it the video capability of the IPhone is impressive. One could probably stack images from it for much better pictures! The phone has a decent but simple image editor and of course it’s internet capable for research and SolarChat.
Celestron has a line of scopes that uses a smartphone as the goto for the scope! And the phone can be used as a goto controller for many brands of mounts.
And the newer iPhones and Android phones take awesome nighttime wide field astrophotos even without a telescope!
I invite all to pick up a smartphone and innovate. You may be surprised at the outcome!
And then there is it’s use as a music player. You can play your soundtrack to your observing session!!
- Has thanked: 1192 times
- Been thanked: 1387 times
Great report James!
Seeing is everything!
Thanks Marty.
I did get me some dense foam from work to make me a 60mm stop down mask for my C102 refractor. It won't cure seeing issues but it will help.
