Experimental big gun today
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Hi all, thought I'd try the big gun today and the baader k-line filter. Seeing was awful, lol but I had to try. Interesting though. Sun was nearing my hedge in the afternoon and I've tree's earlier on so I'm thinking perhaps when it's higher in the sky in the summer there might be some promise. Seeing at midday in the summer might also be unstable.
I did also get data from the Lunt, yet to process yesterday's and today's. Guess I'm going to have a backlog for day's with these lovely clear skies.
Just a screen shot.
Just a screen shot.
- IMG_20210226_150450.jpg (2.16 MiB) Viewed 548 times
- IMG_20210226_150459.jpg (1.36 MiB) Viewed 548 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 9417 times
- Been thanked: 5583 times
Re: Experimental big gun today
As far as I can judge in the image taken from the Laptop screen the result is good. Maybe a screenshot using the snipping tool would look better ?
- Stardust5858
Yeah, I didn't think at the time. We'll see, just experimental. Nothing ventured nothing gained, lol.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 17581 times
- Been thanked: 16698 times
Nice setup!!
- Has thanked: 214 times
- Been thanked: 146 times
Looking good!
No barlow can beat a long native focal length.
CS
Fabio
CS
Fabio
Flickr album https://www.flickr.com/photos/190949744@N08/
- Has thanked: 1071 times
- Been thanked: 1985 times
So many photons!!! Im blind!! Looking forward to seeing the final results
- Stardust5858
Well, here's the initial first light results. Promising as seeing was bad and the sun had almost disappeared behind my hedge. I think it's promising for when the sun is higher than my tree's and hedge. I had to boost the gain so I'm going to try the baader 3.8nd filter. I've got a sheet of that. The current one is 5nd.
- PSX_20210226_193341.jpg (198.3 KiB) Viewed 494 times
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 10248 times
Good try Nigella! You're very brave with the big gun down in the blue.
- Stardust5858
Thanks Mark, fortune favours the brave, lol. My stupidity really, but nothing ventured nothing gained. It's something I'm going to pursue I think considering the results, so pleased I've proven there's some potential. Just need to tweak the nd filter.marktownley wrote: ↑Fri Feb 26, 2021 9:54 pm Good try Nigella! You're very brave with the big gun down in the blue.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 1171 times
- Been thanked: 1360 times
Good first light!
You actually just attempted a lot of things that were up against you. Just for your info, the spherical aberration of your SCT (all SCT) is incredibly poor for this type of telescope due to fast F2 mirror and the corrector plate making it very poor for short near UV wavelengths. Also, these short wavelengths need incredible seeing conditions (well under sub-arc-second) to benefit from with a larger aperture. You would need around 0.3 arc-second seeing to use a 280mm aperture with 393nm wavelengths.
That said, your image is remarkable for the conditions. So, as a suggestion, based on you achieving this with a 393nm filter, had you done this experiment with a red or near IR filter (610nm to 656nm to 685nm) you may have pulled off a rather sharp high res image as the long wavelength is much more durable through atmospheric seeing.
- Stardust5858
Thanks Marty for your comments, it's appreciated. I'll try your suggestion as I've got a 685nm IR filter next. Thanks for the suggestion. It's really nice experimenting, lol.MalVeauX wrote: ↑Fri Feb 26, 2021 10:11 pm Good first light!
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 8418 times
- Been thanked: 8165 times
‘Learning by doing’ as the saying goes. It’s good to try things and find out first hand what works and what does not. I’ve found lots of configurations that don’t work, which makes it even more exciting when you do find that magical combination that produces good results. You do have to appreciate the constraints, though. Aperture, seeing, wavelength, optics, filter quality, camera..... can all conspire against you, one way or another. It can be like threading a very tiny needle to achieve the perfect combination.
- JochenM
- Been thanked: 1619 times
Always nice to tinker and experiment a bit. Results aren't half bad considering the less than optimal conditions.
- Stardust5858
Thanks Stu, yeah, I love just adding things to see what it does. I guess that's science, it's how discoveries are made, not saying I'll discover something new though, lol.Carbon60 wrote: ↑Sat Feb 27, 2021 7:21 am ‘Learning by doing’ as the saying goes. It’s good to try things and find out first hand what works and what does not. I’ve found lots of configurations that don’t work, which makes it even more exciting when you do find that magical combination that produces good results. You do have to appreciate the constraints, though. Aperture, seeing, wavelength, optics, filter quality, camera..... can all conspire against you, one way or another. It can be like threading a very tiny needle to achieve the perfect combination.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Jochen, I was pleased with the results considering the restraints. When the sun is higher I'm still going to try the K-Line. For now I'll be trying the 685nm IR see what that does.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 9145 times
- Been thanked: 6027 times
Excellent first light Nigella. I am a bit like you, I try to take out my large scope even in unfavorable conditions. Sometime it pays off, taking some risk is part of this hobby.This time it paid off for you.
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
It's a fine result given the conditions you had. Yes, SCTs are not fine performers in the near UV however the aperture helps and in fine seeing condition one should be able to do better than with a small refractor.
Raf
- Stardust5858
Thanks Franco appreciate your comments. Yeah, I agree Franco.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
