The (very long and drawn out) relocation is finally winding down, and I was able to get the solar scope out in the backyard again after about 3 months of not being able to do any imaging at all. Felt good to be out again and almost done with the move!
Images captured at about sea level on a singestack lunt 100, with meteoblue saying I had about 2 arcseconds of seeing. Both images were single captures, then using masked stretch with a range selection to stretch the filaments into view. Full disc is also single image using the 0.5x reducer (cheap one, edges are a bit soft vs the center) on the 178mm. Partial disc is pure 178mm. Processing is a bit rusty as I forgot some of my workflow and coloring settings, but good to be out none the less.
Partial and full disc views from the 26th
- AJamesB
- Has thanked: 1150 times
- Been thanked: 630 times
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: Partial and full disc views from the 26th
Lovely captures, it must feel great to get back to your solar imaging. I get withdrawals if I don't see the sun. Here in the UK I can go weeks, especially in the winter months. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Wow, great spectacular captures!
Raf
- Has thanked: 9401 times
- Been thanked: 5561 times
WOW, those two proms from a few days ago went into a huge one ...
- Has thanked: 20424 times
- Been thanked: 10243 times
They came out well, glad you're able to get the scope out again properly!
- Has thanked: 17667 times
- Been thanked: 8787 times
- JochenM
- Been thanked: 1619 times
- Been thanked: 4340 times
Superb images and that prom is wonderful catch
- pedro
- Has thanked: 14 times
- Been thanked: 6576 times
great images with the LUNT100
Pedro Re'
