hello since a long time a picture of the sun from 26.2.. the seeing was very good partly up to 0.4/0.8", i used 8% of 1400 pictures, taken with a 150mm maksutov,
daystar quantum with ls50 DS asi174mm
Martin
Sun 26.2. 150mm Mak
- Been thanked: 16693 times
Re: Sun 26.2. 150mm Mak
Nice with a lot of contrast.
- Has thanked: 20435 times
- Been thanked: 10245 times
Nice outcome Martin! Are you using a SSM?
- huwiler
- The Sun?
- Been thanked: 30 times
hello, thanks for the nice feetbac, yes i use a ssm but not yet on the cumputer, i watch the camera image and the ssm and then activate the recording when the seen is good. maybe it is still more efficient to automate this i don't know.
martin
martin
- Been thanked: 4340 times
Hi Martin...
Nice set of images!!!
