Sun in Ha and CaK 1st March '21
Has thanked: 8523 times
Been thanked: 8259 times
Post by Carbon60 »
Just a couple of FDs today in Ha and CaK. The CaK image (mosaic) is a bit patchy, but I'll take it. The secondary filter (omega) was playing up and I struggled to achieve a uniform view, rotating it this way and that to try to null out an annoying lighter band down the centre. Some more tinkering is required....
The Ha FD was imaged using my DS Lunt 60.
The conditions today were pretty good, although slightly hazy with the dregs of earlier fog just ebbing away, slowly.
Image20210301_CaK_FD_mono by Stuart Green, on Flickr
Image20210301_CaK_FD_colour by Stuart Green, on Flickr
Image20210301_Ha_FD_mono by Stuart Green, on Flickr
Image20210301_Ha_FD_colour by Stuart Green, on Flickr
I'm really pleased with the Coronado BF on the Lunt. It's so much easier to get the scope and front etalons tuned up for more uniform FDs than I could achieve with the Lunt BF. I'm sure mine must be defective. The image is also much brighter with the Coronado allowing shorter exposures.
Thanks for looking.
Has thanked: 17925 times
Been thanked: 8894 times
Re: Sun in Ha and CaK 1st March '21
Excellent Stuart :bow :hamster: just like what I saw this morning although I thought the seeing was very bad here ;) I also had blocking filter trouble, will tell you later :(
Has thanked: 17813 times
Been thanked: 16953 times
Post by DeepSolar64 »
Excellent work Stuart! Thanks for the wonderful views. I am under an overcast cloud deck today.
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Post by JochenM »
Nice set of disks there, Stu.
Jochen Maes
Belgium
https://www.jochenmaes.com
Has thanked: 20757 times
Been thanked: 10444 times
Good looking disks Stu. Just fog and low cloud for me today.
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Hi Stu...
Nice FD images from the session :bow
MAURITS
Has thanked: 2463 times
Been thanked: 4879 times
Post by MAURITS »
Beautiful images Stu
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
