Today's SUN (20210301) | SM90II - not just a paperweight
- pedro
- Has thanked: 14 times
- Been thanked: 6576 times
The SM90II/SM60 combo seems to be working fine. Not easy to adjust the two etalons though
WEB LINK:
http://pedroreastrophotography.com/sun_ ... 21-03.html
Solar imaging session (20210301) | Pedro RE'
LUNT60, JAEGERS5" (SM90II/SM60)
GS3-U3-28S4M, Takahashi EM-400
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
SUN (20210301) H-alpha PROMS (15:00 UTC). LUNT60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20210301) H-alpha PROMS (15:30 UTC). JAEGERS5" F/5, DS SM90II/SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S5M
SUN (20210301) H-alpha PROMS (15:30 UTC). JAEGERS5" F/5, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S5M
WEB LINK:
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
Pedro Re'
- Has thanked: 20432 times
- Been thanked: 10243 times
Re: Today's SUN (20210301) | SM90II - not just a paperweight
Interesting results Pedro! Sometimes it's just about finding that right combo.
- pedro
Thanks Mark
I used this combo visually with a TMB100 f/8 a few months ago. It seems to work fine although I'm restricted to 60 mm aperture...
- TMB_SM60_SM90II_BF15_20200411-042.jpg (733.48 KiB) Viewed 463 times
- TMB_SM60_SM90II_BF15_20200411-039.jpg (1.46 MiB) Viewed 463 times
- TMB_SM60_SM90II_BF15_20200411-038.jpg (1.07 MiB) Viewed 463 times
- TMB_SM60_SM90II_BF15_20200411-034.jpg (799.84 KiB) Viewed 463 times
Pedro Re'
- Has thanked: 8415 times
- Been thanked: 8161 times
Looking good, Pedro. Could be a winning combo.
- Been thanked: 16693 times
That's an interesting setup. See, Meade Coronado isn't all bad.
Jaegers. I haven't heard that name in awhile. They were well known for quite a number of years. I wonder what happened to them.
Splendid images as typical of you, Pedro.
- pedro
Thanks Stu & James
Jaegers built great achromats in the 70s.
http://www.astrosurf.com/re/1973_jaegers-01.jpg
http://www.astrosurf.com/re/1973_jaegers-02.jpg
https://web.archive.org/web/20151017201 ... aegers.pdf
Pedro Re'
- pedro
- Been thanked: 4340 times
Superb series of images Pedro
The 90/60mm DS looks very good...too bad the 90mm is limited to this use to get the best out of it. I'll bet it adds a lot of weight to the scope!
- Has thanked: 17667 times
- Been thanked: 8788 times
Not bad Pedro, you just need to buy another SM90 to match it to
- pedro
Thanks Brian & Alexandra
Yes, I was thinking of buying another SM90 too...
I adds some weight but the Taka EM400 is very sturdy
Pedro Re'
Another 90mm...I'll bet you want to be able to test it to ensure it is worth more than the 60mm equivalent value of the one you have
- pedro
I will buy one if I can find a good pre-Meade etalon and try it first.
Pedro Re'
I bet pre-Meade etalons are hard to find. I came into this Ha game way too late.
- pedro
They are available but you have to pay...
Pedro Re'
- Been thanked: 4786 times
- pedro
thanks Maurits
Pedro Re'
