April 8 2021 Observations
Has thanked: 17807 times
Been thanked: 16942 times
Post by DeepSolar64 »
Session time is 11:54am until 12:28pm EDT local time. The skies are overcast with thin clouds with a broken lower heavier cloud deck. The seeing is fair. The temperature is 70F.
Coronado SolarMax II 60 DS. 16x and 21.5x ( Ha )
I first off notice a fairly long dark filament in the NE stretching from a barely visible plage to the limb running diagonally NE-SW. The GONG CT Ha image shows a couple of other small filaments to the NW of the bigger filament but I never could see them through the cloud cover. I see one more filament on the disc with difficulty. It's in the south close to the central longitudinal meridian and is associated with a faint plage there. I could not see the plage.
I could see two prominence groups on the limb. One bright elongated group in the SW and another pair in the NW.
Despite the high thin cloud cover I can see the mottles. Low of contrast but there.
I can see two patches of faculae on the disc. An easy patch in the southeast quadrant not far off the limb and a more difficult patch near the NW limb. I can see the very fine granulation but only at 50x with difficulty. No pores or spots seen.
Carpe Diem!
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: April 8 2021 Observations
Post by EGRAY_OBSERVATORY »
Thanks for your latest report James (from my now-operational observatory-computer. [loose internal connector-suspected]).
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Post by Stardust5858 »
Thanks James for your report. Clouded out here still😭
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
I was lucky to have gotten a session in today. The clouds were sun-penetrable for only about an hour today and I seized the opportunity. The skies are forecast to be mostly cloudy to cloudy tomorrow and it doesn't look too good for a session tomorrow.
Been thanked: 10430 times
Things seem to be quiet again apart from the filament and couple of proms James. Rain here today, but better weather forecast for the weekend which is good. Todays mission is to make a sliding door for the brewery before some quality control of product later in the afternoon, at least we have some tunes while we work now ;)
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Thanks for the update James.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 17894 times
Been thanked: 8887 times
Great report James :hamster: but no chance of Sun here today :(
Sorry Montana. I am with you today on the clouds.
