Visual Report 13/04/2021
AndiesHandyHandies
Has thanked: 3304 times
Been thanked: 1902 times
Post by AndiesHandyHandies »
Still with thin clouds but clear breaks.
127mm Triplet UV/IR 4.2x Quark Chrom 40mm Plossl
10.40 BST
See the spiricules and mottles on the surface.
1.00 One large prom on today. Pyramid on left and smaller one on right. Diffuse dumpy pyramid prom in between. On the right of the smaller pyramid a little feed with a space around it.
2.00 Tiny spike
4.00 Little jet pointing down with thicker jet going off the end upwards and two antenae off the top.
10.00 Tiny upward leaning spike.
I see a dark spot in the feature with a dark bar above left and one below it. To the right is the bright armchair still with a small dark spot under the seat by the left leg. 3 bright spots under joining the two spots.
Cheers. Andrew.
AndiesHandyHandies
Re: Visual Report 13/04/2021
Carbon60 shows a tall faint prom.
Going back I missed a thin leaning up prom at 8.00 for me, opposite side to the large prom.
5.00am Learmonth shows that.
It also shows a series of proms opposite, from the 4 prom group yesterday? Have another look for those.
Cheers. Andrew.
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
All gone when I looked this morning.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
