So, I was doing some testing between 8 bit and 16 bit mono, as well as bewteen avi and ser in bit (surprise, 16bit ser is the best by a wide margin), but unfortunately my last test capture before going for the time lapse was the 8 bit ser video, so this time lapse is also unfortunately only in 8 bit, which caused a sizeable loss in detail as well as some crazy gradients in the background. Lesson learned, always double check your settings before starting a project, lol. Seeing had degraded by the time I was done with test and single image captures, so the finer details were kind of doomed anyways.
The small active region was the only semi-bright spot I could see on the main disc of the sun, with a small possible spot forming maybe?
Lunt 100 single stack with asi294+2x telecentric and ROI
Still image of small active region on disc, and a 7 second time lapse covering an hour of prom activity today
- AJamesB
- Has thanked: 1154 times
- Been thanked: 630 times
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
- Has thanked: 17853 times
- Been thanked: 16996 times
Re: Still image of small active region on disc, and a 7 second time lapse covering an hour of prom activity today
Nice work ! The animation is great! Nice coloration too.
As Maurits and James confirm, you have done well to animate this active-prominence.
