Between the clouds a quick recording.
Quark Chromosphere
ASI 174MM and Interference Eliminator.
TOA-150
And a lot of bad seeing, I could only record maximum 500 frames ...
The black surface images are captured with a higher Gain.
All the records are done with SharpCap, I had today a lot of problems with FireCapture.
13 April
- Been thanked: 4786 times
Re: 13 April
Hello Maurits, your captures and processing are simply fabulous with so much fine-detail and colouring.
The proms are exquisite.
Thanks for sharing
Regards
Thanks for sharing
Regards
- Been thanked: 16689 times
Re: 13 April
There is a lot of detail in all of these. Vertical striations in the prominences show clearly and the plasma loops near the active region show up very clearly. Excellent photo documentation Maurits!!
Re: 13 April
Thanks Terry, between the clouds the seeing was fair this time to maximum 500 frames recording.
The close-ups from the sunspot were recorded in less good seeing.
- Has thanked: 1640 times
- Been thanked: 878 times
- Has thanked: 8415 times
- Been thanked: 8161 times
Re: 13 April
Beautiful results, Maurits. Lots of lovely details.
- Has thanked: 9143 times
- Been thanked: 6024 times
