Yet more sunshine..... 16th April 2021
- Has thanked: 8587 times
- Been thanked: 8322 times
We've been very lucky in many parts of the UK with a run of great weather over the past week or so. This morning I managed a few images in Ha and Ca II K at various image scales including some closer views of the main active regions in both lights.
I'll let the images speak for themselves (it's late and I'm tired after a day of decorating, such is the price for an hour or two of imaging).
Ca II K FDs on a 72mm f6 refractor (Lunt B1800 module).
20210416_CaK_FD by Stuart Green, on Flickr
20210416_CaK_FD_colour by Stuart Green, on Flickr
....and some closer views on a Tecnosky 125. The main active region (AR12814) was really quite bright in comparison to the main disk and it ended up a little over exposed.
20210416_CaK_AR12814_Mono by Stuart Green, on Flickr
20210416_CaK_AR12814_colour by Stuart Green, on Flickr
20210416_CaK_AR12814_x5_Mono by Stuart Green, on Flickr
20210416_CaK_AR12814_x5_Colour by Stuart Green, on Flickr
Over to the red end on a Lunt 60 (TS).
20210416_Ha_FD_Mono by Stuart Green, on Flickr
20210416_Ha_FD_colour by Stuart Green, on Flickr
....and again some closer views of the main event and the new AR, captured on my 150mm/Lunt 35 mod.
First up is the newest active region just in view on the eastern limb.
20210416_Ha_Limb AR by Stuart Green, on Flickr
...and the other active regions...
I forgot to orientate these correctly. Doh....
20210416_Ha_AR12814_New AR_Mono by Stuart Green, on Flickr
20210416_Ha_AR12814_New AR_Colour by Stuart Green, on Flickr
Finally a solo view of the main active region (AR12814)
20210416_Ha_AR12814 by Stuart Green, on Flickr
20210416_Ha_AR12814_Colour by Stuart Green, on Flickr
As always, thanks for looking.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: Yet more sunshine..... 16th April 2021
Lovely captures Stu, I saw similar.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Martin_S
- Has thanked: 999 times
- Been thanked: 3061 times
Great Imaging Stu, It's good to see the UK getting some good viewing weather.
Martin
Martin
- Has thanked: 9361 times
- Been thanked: 6193 times
- Been thanked: 5005 times
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Terrific images, Stu.
I envy you your weather. We just emerged from a big snow dump several days ago and more snow on the way tomorrow
I’m champing at the bit to get some imaging done.
Peter
Peter
- DJD
- Has thanked: 42 times
- Been thanked: 133 times
Fabulous detail Stu, and beautiful images. Very productive session, the seeing looks like it
was a bit better in your kneck of the woods.
I am glad I am not the only one that has to do a bit of penance after
getting time off for some imaging. I am being "encouraged" to get the strimmer out.
David
David
- Has thanked: 20908 times
- Been thanked: 10564 times
Very nice set Stu, just about to head out here thins morning....
Many thanks, everyone.
- Has thanked: 17920 times
- Been thanked: 17061 times
WoW Stuart! Your images have really nice resolution, especially in the light of CaK!!
What 72mm f6 refractor are you using? I have a an Astro-Tech scope of that size and fl. It will probably be the one I use for CaK when I get the filter.
- AJamesB
- Has thanked: 1154 times
- Been thanked: 630 times
Fantastic detail, love it!
Lunt ls100tha single stacked + hinode solar guider on ioptron cem26 mount
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
Hi James,DeepSolar64 wrote: ↑Sat Apr 17, 2021 4:53 pm WoW Stuart! Your images have really nice resolution, especially in the light of CaK!!
I use an Altair Astro Lightwave for FDs. It isn’t anything special. I bought it for the 2017 US eclipse because it’s light and isn’t too expensive for travel. My only complaint is that the focuser is a bit weak (drifts out of focus with the weight of the module and camera) and I have to keep tightening the thumbscrew to lock it in position. There’s also a bit of slop in the focus back and forth.
It works, but there are better solutions.
For close views I use a Tecnosky 125 (Tecnosky 125/975 F7.8 FPL-53 ED Doublet APO Refractor Telescope).
Hope this helps.
- Has thanked: 2496 times
- Been thanked: 4917 times
- Ivan
- Has thanked: 3497 times
- Been thanked: 2282 times
Beautiful photos. Excellent quality, I had great pleasure looking at them. You have done a great job. Looking at them, I understand what you need to strive for.
- Has thanked: 65 times
- Been thanked: 4443 times
Excellent image Stuart
Good to hear that the weather has improved !!!
Carbon60 wrote: ↑Sun Apr 18, 2021 7:19 amHi James,DeepSolar64 wrote: ↑Sat Apr 17, 2021 4:53 pm WoW Stuart! Your images have really nice resolution, especially in the light of CaK!!
Hope this helps.
Your Astro Lightwave refractor sounds a lot like my 70mm Orion WL solar refractor. It isn't the best with the focuser being it's weakest point but it works and didn't break the bank. It too is light and portable.
