Visual Report 19/04/2021
AndiesHandyHandies
Has thanked: 3321 times
Been thanked: 1907 times
Post by AndiesHandyHandies »
127mm F7.5 Triplet Baader 2" UV-IR 4.2x Quark Prom 40mm Celestron Plossl
Clear and still
11.50 BST
Mirror image of Gong.
1.00 Three legged Mars spaceship.
3.30 Open pyramid prom with a spray prom with top connection half way to pyramid.
4.00 Dumpy Prom
6.30 Two H proms. Lower one smaller, feed to bottom leg of top one.
8.00 Faint spray
10.00 Two faint sprays lower one larger.
Under 9.00 Sunspot group.
Under 3.30 Sunspot group. Two roughly horizontal spots, tadpole pointin down on lower right. Seperated tail above.
Add 28.5mm stop to Baader UV-IR on diagonal nose.
12.10 BST
1.00 Small jet leaning down to Mars spaceship and a 4th seperated leg.
4.00 Small jet above leaning down.
Under 5.00 dark filament pointing to sunspot group.
7.00 Tiny bump
8.00 Faint jet
9.00 Little jet with top extension.
Spiricules and mottling good.
32mm Meade SP
4.00 Fuzzy seperated jet with oval jet on stalk and a little spay jet from top side
Under 3.30 sunspot group, Can see two extra small spots near the horizontal one. Tadpole tail has a small dark spray behind.
25mm Clave'
5.30 Hedge prom with 4 feeds Two lobes lower top, bottom hollow and higher brighter. Thin faint jet below.
7.30 Hs, top one two jets with lower one two parts, more like a U shape now. Smaller lower H two jets bending towards each other.
11.00 Wine glass WG with lip, with bright blob above the middle of the top. Little bright blob off the bottom lip. Top side WG has double jets, and a jet then leaning to the double jets with rain under its top. Little jet out of top middle of WG.
12.40 BST
Fujiyama 25mm Ortho
5.30 Hedge prom with feeds. Small hollow lobe at the top larger hollow lobe below. Small jet going off top above. Side jet off small lobe leaning down.
Seeing gone.
Cheers. Andrew.
Has thanked: 17860 times
Been thanked: 17004 times
Re: Visual Report 19/04/2021
Post by DeepSolar64 »
That's a really nice report Andrew. It sounds like you had good seeing conditions.
Has thanked: 17974 times
Been thanked: 8907 times
Excellent report Andrew :hamster: I would have loved to see the Mars spaceship myself but the wine glass sounds nicer :)
