Here are 2 animations of the main visible sunspot regions, a 30min timelapse for the smaller, departing region and a 1hr for the slightly larger region. Data is from the 19th of April.
I normally do an image every 30 seconds for my timelapses, but this time tried an image every 60 seconds instead, and I think its just a bit to much time inbetween captures to maintain smooth movement in the smaller structures, so I'll go back to doing images every 30 seconds when smaller structures will be included. I think 60 seconds would be enough though for larger prominences, where movement is slower or over greater distances.
Lunt 100 single stacked with asi294mm at bin2 and 4x telecentric + ROI of about 2100x1400
Timelaspe animations of the 2 visible sunspot regions, from the 19th of April
- AJamesB
- Has thanked: 1154 times
- Been thanked: 630 times
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
- Has thanked: 9313 times
- Been thanked: 6153 times
Re: Timelaspe animations of the 2 visible sunspot regions, from the 19th of April
My iPad could not load the first one but the second one is excellent. Thank you.
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Good work ! Good detailed - I like the Lunt 100 ! I wish I could afford such an expensive telescope.
I am thinking of doing animations as well, but maybe 15 seconds in between files (only pause for 15 seconds between end of one and the start of the next).
DId you do any processing, deconvolution, unsharp masking, levels, contrast, and curves adjustment at all -
and then aligning of the images ?
Thanks.
Magnus!
Thanks.
Magnus!
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- Radon86
Hi AJamesB,
I was wondering what telecentric barlows did you use ? (Televue powermates) and telecompressors?
Sounds very technical. I would like to get better flat field images but wonder how to do this, and find the right one to use for your solar imaging system..
Thanks.
Magnus
Thanks.
Magnus
Fines animations James - thanks for sharing
- AJamesB
For this setup using the larger sensored asi294mm, I used a Baader 4x telecentric. Its on the spendy side, but its fantastic and optimized for h-alpha. When doing similar sized imaging but with my smaller sensored asi178mm, I only need a 2x, and for that I use a Televue brand as its cheaper than the baader but still gives a nice flat image on my lunt. I haven't used it on other telescopes though so I don't know if that flat field will translate equally well to other scopes.
For telecompressors, I had just been using a cheapo 0.5x that worked well with the small sensor of the asi178mm, but it did get really soft around the edges when doing full disc images with it. I recently upgraded that to a Solar Spectrum 0.4x which, while also not cheap, was sharp edge to edge, and while I wasn't looking for it specifically, no field unevenness jumped out at me.
This would be a great post though to make in the main forum, as there are so many people with so much more knowledge than what I have, and who would know what specifically to recommend for the specific telescope or system that you have. I'd recommend doing that, because there could be reasons why what works for me may not work for you or your setup.
Oh yes, absolutely. I did deconvolution, alignment, then more alignment, then stretching with masks in pixinsight, adjustments, etc., all the things one would do for a still image, just using batch processing to do it to everything. Then to get the extra smoothness, I do video framrate interpolation which takes the fps from 12 up to 60, giving it that smoothness of motion.DId you do any processing, deconvolution, unsharp masking, levels, contrast, and curves adjustment at all -
It all sounds complicated and time consuming, and the learning process is time consuming, but once you get it all down it actually goes pretty quick. My first timelapse probably took me about 6 hours (not including computer processing time) as I had to follow tutorials for each individual step, but now I can kick one out in about an hour. So it does get better, lol.
asi178mm
asi294mm
asi178mm
asi294mm
- AJamesB
asi178mm
asi294mm
asi178mm
asi294mm
These are beautiful to sit and stare at, so much going on in both
Great details James.
- Has thanked: 20803 times
- Been thanked: 10478 times
Great movies!
