Well AR2817 may have disappeared from the visual northern-hemisphere, but it looks as if it is about to be replaced by a new AR in the
Northern-Central region, as the latest SDO image shows. Small and faint, three-spots are clearly visibubble...
(Rainer - " Your Wish is my Command " )
MORE CLEAR SKIES
23-4-2021 A NEW NORTH-CENTRAL AR - WITH SPOTS TODAY
- latest_2048_HMII.jpg (359.41 KiB) Viewed 210 times
Re: 23-4-2021 A NEW NORTH-CENTRAL AR - WITH SPOTS TODAY
If that is true it looks like a very high latitude region, we need those as an indicator of a very active cycle ahead we want a mega cycle not a weak one.
Thanks again Maurits and Alexandra.
I did check my screen for any dust-bunnies and so SDO have certainly captured this new event.
Let's hope things can only get better with another AR...
In fact, just checked with SDO again and their hi-resolution/4096 capture - shows this is definitely an AR with three-spots at about 17:00Z...
- Has thanked: 17853 times
- Been thanked: 16996 times
I got the new spot in continuum and the faint plage in Ha.
Well "spotted" then James, as they are not too easy to see.
Regards
Regards
- viewer
- Has thanked: 233 times
- Been thanked: 23 times
Looks one of the spots is bigger already?
Eq-2 mount on the balcony, pst, mak with baader filter, zoom, camera asi290mm
Sketches and images: https://www.cloudynights.com/gallery/me ... 07-viewer/
Thank you "viewer" and yes that is perfectly correct.
Will have to wait and see what it is like on Saturday morning
