Here are two images taken in Ca K on April, 22 and the Taka TOA150 :
Full-disk image with ASI 1600:
http://astrosurf.com/viladrich/astro/so ... a-Barr.jpg
AR2816 with ASI 290 :
http://astrosurf.com/viladrich/astro/so ... ASI290.jpg
Clear skies !
Ca K double stack images with TOA 150 - April 22
- Been thanked: 2725 times
- Has thanked: 20834 times
- Been thanked: 10503 times
Re: Ca K double stack images with TOA 150 - April 22
These are excellent Christian! What sharpening routine do you use? Unsharp mask or Lucy Richardson deconvolution?
Absolutely excellent Christian and thanks for sharing
Thanks Mark and Terry !
Mark, my processing flow is very simple. It is the same for Ca K, Ha or white light HR images. I use AstroArt, but it can be done with any other software
- unsharp masking : sigma = 1.4 pixels and coefficent 8,
- very small amount of RL deconvolution : sigma = 1.1 pixels (gaussien), 2 iterations,
- adjustments of min/max levels as need in Photoshop,
- no gamma change (except on prominence Ha images).
For FD images, I only use unsharp masking since contrast is very strong due to sampling:
- unsharp masking : sigma = 1.4 pixels and coefficent 6.
Hope this helps.
Hope this helps.
- sulcis2000
- Has thanked: 2 times
- Been thanked: 477 times
A pleasure for my eyes!
Alessandro Bianconi
________________
Celestron C14HD Edge
Celestron C14XLT made in USA
Refractor 228 F8 Truss Tube with D-ERF 110mm
Sharpstar 76PHED
Daystar Quark Chromosphere version
Daystar Quark Calcium H
Starizona Hypestar V4
10 Micron GM2000HPS II Mount
Ioptron CEM120 Mount
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
Basler Aca1920-155um
ZWO ASI462MC
Celestron Skyris618M
________________
Sharpstar 76PHED
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
ZWO ASI462MC
- Been thanked: 4434 times
Fabulous images Christian
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Another fabulous Ca set, Christian.
It's always a pleasure to view these.
Peter
Peter
