Catch up 11th May 2021
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Hi all, just catching up on processing. I did manage to capture the flare in one of my HA images, though not great seeing, did come out OK. Some Cak and WL added to. Not a great collection.
- 20210511-083513UTellabryant-HAFDflare-col.jpg (1.39 MiB) Viewed 152 times
- 20210511-092606UTellabryant-WLAR-col.jpg (737.58 KiB) Viewed 152 times
- 20210511-092606UTellabryant-WLAR.jpg (677.51 KiB) Viewed 152 times
- 20210511-080523UTellabryant-CaKAR-col.jpg (712.67 KiB) Viewed 152 times
- 20210511-075823UTellabryant-CaKproms-col.jpg (288.15 KiB) Viewed 152 times
- 20210511-075526UTellabryant-FDCaKproms-col.jpg (744.02 KiB) Viewed 152 times
- 20210511-093900UTellabryant-FDCaK-invert-col.jpg (935.4 KiB) Viewed 152 times
- 20210511-075103UTellabryant-FDCaK-col-closeup.jpg (713.68 KiB) Viewed 152 times
- 20210511-075103UTellabryant-FDCaK-col.jpg (950.38 KiB) Viewed 152 times
- 20210511-083513UTellabryant-flare-invert.jpg (809.23 KiB) Viewed 152 times
- 20210511-083513UTellabryant-flare-eb.jpg (699.2 KiB) Viewed 152 times
- 20210511-083513UTellabryant-HAFDflare.jpg (1.04 MiB) Viewed 152 times
Last edited by Stardust5858 on Sat May 15, 2021 10:22 pm, edited 3 times in total.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Re: Catch up 12th May 2021
I think I caught a C1.5 flare in calcium II K. Mostly CaK but a couple of FDHA. Of course I might be wrong but there is definitely a brightening within AR 2822 on the images taken at 09:37UT and 09:47UT the same time as the noted flare beginning at 09:15UT and ending 09:47UT. See post for 12th May.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 10487 times
Re: Catch up 11th and 12th May 2021
Nice set of results Ella!
- Stardust5858
Thanks Mark, appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
An excellent set of captures Ella and many-thanks for sharing your colouring results and efforts too.
Regards
Regards
- Stardust5858
Thanks Terry, eventually caught up, lol. Trying to capture CaK right this minute but fast moving clouds and wind blowing the dome, lol. Sat in the dome listening to 2021 compilation on YouTube, lol. Take care.EGRAY_OBSERVATORY wrote: ↑Sat May 15, 2021 2:39 pm An excellent set of captures Ella and many-thanks for sharing your colouring results and efforts too.
Regards
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Maurits, appreciate your comment.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
