Heads Up 17th May
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Heads Up 17th May
Another unexpected session this morning after my run when the clouds parted. I was out running and the sky cleared, ran faster to get back home and open up the dome. Screenshots for info. Two lovely proms, one north and one south. AR2822 still holding up with one spot. Can't see any other spots but four areas of faculae and plage area's. looks like a plage area just visible on the North East quadrant. I took off the 360 degree clocking rotator on the lunt 60mm and had difficulty getting even illumination, wish I hadn't so it's gone back on but the clouds came in again. Why do we do silly things?
- Screenshot (46).png (1.2 MiB) Viewed 180 times
- Screenshot (42).png (774.23 KiB) Viewed 180 times
- Screenshot (44).png (791.1 KiB) Viewed 180 times
- Screenshot (43).png (784.44 KiB) Viewed 180 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4881 times
Re: Heads Up 17th May
Beautiful and already sharp images durig the recording Ella, looks that you have stable air.
- Stardust5858
Thanks Maurits, yes, for once I had some stable air. Hopefully get them processed and posted tomorrow. Supposed to be raining tomorrow so it can be done then, lol.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
So Ella, is it the running or the de-clocking that are the "silly things" ?
What is far from silly though, are your excellent screen-shots again and yes of course you have spotted the newbie in the N.E., so well done there and that one - could be very interesting over the next-days...
Best Wishes
Best Wishes
- Stardust5858
Definitely the running is silly, lol. At least that's what I think in the middle of the run. Only joking, yes, the North Eastern quadrant does look very interesting, large spot apparently. Hopefully we'll get some sun. I've done quite well recently as the forecast each day gave thunderstorms but I've had some clear sky for a few hours each time.EGRAY_OBSERVATORY wrote: ↑Mon May 17, 2021 5:34 pm So Ella, is it the running or the de-clocking that are the "silly things" ?
Best Wishes
Take care Ella
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 20828 times
- Been thanked: 10502 times
Thanks for the heads up ELla, cloud and showers persist here...
