Animation: The End of the NE "floating Prom" of 13 June 2021
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Hi all,
The seeing was better and I started with the animation captures of the NE prom (called "the floating prom" by James earlier). The problem was that for the 35 first captures I forgot the Gamma on at 100 (after contrasting to focus). Therefore, the first half of the animation (that also had the best seeing) could not be saved by processing and the effort to make my first one hour animation failed. It happens... Nevertheless, I can share with you the last 36 captures made during 25 minutes.
Lunt130MT masked @102 mm, Blue wing of H-Alpha for the first photo. And the animation... PEASE give it the time to load properly. Hope you like them.
Alexandros
Alexandros
Alexandros
Greece
Greece
- Has thanked: 17835 times
- Been thanked: 16976 times
Re: Animation: The End of the NE "floating Prom" of 13 June 2021
Alexandros,
That first photo looks like a white light continuum image. I love the last one. That floating prom got sucked right back in!
- H-Alpha
Thanks a lot James.DeepSolar64 wrote: ↑Mon Jun 14, 2021 1:12 am That first photo looks like a white light continuum image. I love the last one. That floating prom got sucked right back in!
Yes! As far as I understood from a previous discussion we had by the end of May in the following post:
viewtopic.php?f=4&t=31951&p=293626#p293626
...when we are completely off band towards the blue end of H-alpha at the far Blue Wing of H-alpha, we get an image very similar to WL, but in reality we look at layers just a little bit upper than the Photosphere layer. The result is very similar, but some people "prefer" the Continuum WL because the granules appear more contrasted aesthetically and more "boiling". Therefore, I think it is very close to WL, but not exactly.
If I am wrong, some people here will correct me, I hope.
Alexandros
Alexandros
Greece
Greece
Alexandros,
That then reminds me of the sodium d line filter. It too shows an area just above the photosphere as shown in white light and gives a very similar image but adds a little detail particular to that emission line. To that area very close to the photosphere.
- Has thanked: 17970 times
- Been thanked: 8904 times
Superb images the animation is amazing watching the plasma flow down from the anchor spot
- Has thanked: 9307 times
- Been thanked: 6144 times
Beautiful shots and a very cool animation, Alexandros
- Dave Smith
- Has thanked: 203 times
- Been thanked: 335 times
That is a wonderful animation.
Dave
Dave
Solar kit: LUNT LS80MT B1800 FT DS Solar telescope, Rowan tilt adapter and ZWO ASI 178MM camera.
For white light, William Optics Megrez 90 and Lunt Herschel wedge. Software: FireCapture, AS!4, Imppg, Affinity Photo.
Images on the web https://www.astrobin.com/users/dwgsmith
- Has thanked: 8543 times
- Been thanked: 8278 times
Excellent, Alexandros. Great animation.
- H-Alpha
Dear James, Alexandra, Franco, Dave, Stu,
Glad you liked the animation and many thanks for your kind words!
Best wishes and clear skies!
Alexandros
Alexandros
Alexandros
Greece
Greece
- Been thanked: 2725 times
The animation is fascinating Alexandros. Well done !
- H-Alpha
Thanks a lot Christian!
It seems I was lucky to capture the moment even with half the frames of the originally captured. ;-)
Alexandros
Alexandros
Alexandros
Greece
Greece
