I have been tormented by cloud and soft seeing this morning.
So I fiddled with the PST etalon and spacers to pass the time.
Then the seeing improved and I captured this between the clouds:
Added two more before the seeing crashed:
15.06.2021 AR12833 Patience is rewarded.
- Rusted
- Has thanked: 8172 times
- Been thanked: 1943 times
- minhlead
- Has thanked: 739 times
- Been thanked: 1107 times
Re: 15.06.2021 AR12833 Patience is rewarded.
Nice pic, Chris
Minh.
Loves from Viet Nam <3
My gear:
Scope: SkyRover (Kunming Optics) 152mm F/6 Doublets
Mount: JTW Tridents GTR
Camera:
PlayerOne Apollo M-Max
Quark Chromosphere Doublestacked with PST etalon
My gear:
Camera:
- Has thanked: 9319 times
- Been thanked: 6157 times
Absolutely an excellent capture Chris, so thanks for your patience, sharing and CLEAR SKIES.
This active region is still going strong, that's a very big spot
- Rusted
Thank you all for the kind words.
The seeing was almost steady but not particularly transparent.
I re-wrapped the PST etalon in Teflon plumber's tape yesterday.
The alignment seems to have improved over completely naked.
I have another 50 frame, PIPP AVI animation which runs like a video of a still image.
It doggedly refuses to move. Anybody got a spare taser or defibrillator?
"Clear!" ZAP!! It's alive!
- Ivan
- Has thanked: 3483 times
- Been thanked: 2263 times
Great shots, it's always nice to be in time before clouds cover the sky.
Ivan
Ivan
- Has thanked: 2464 times
- Been thanked: 4880 times
- Rusted
Sorry David and thankyou. I only spotted your question as I was closing down at bedtime.
I used an old, secondhand, Celestron 150/8 prior to the iStar. Later with the 1.125 Baader GPC.
The iStar 150/10 H-a objective seems like a much better quality lens than the Celestron. It is certainly a heavy beast!
I had opted for their H-alpha lens at considerably greater expense than their standard achromat.
Assuming that the much larger price tag would [hopefully] provide better optical work and testing.
Though I concentrate almost entirely on solar close-ups, I have also used the H-a lens for lunar imaging.
It provided nicely satisfying, lunar close-up images with a Baader Solar Continuum filter and ASI174MM camera.
I also have the iStar 180/12 R35 and found that to be a nice lens too.
I was immediately using it regularly at up to 300x visually on the Moon.
The Celestron would never allow much over 120x!
Both lenses are mounted in their own, oversized, thin, galvanized steel, ventilation ducts.
These are straight seamed rather than the regular, spiral wound.
The idea of the straight seam is that it doesn't collect inflammable dust.
It also looks much smarter than the spiral wound type IMO.
The low, straight seam is easily arranged at the hinge gap of standard "Skywatcher" tube rings.
Here's one of my blog posts on the iStar 150/10 H-a lens:
https://fullerscopes.blogspot.com/2020/ ... alpha.html
