AR2883 on June 16 with the Hat 8 and double stack Ha
christian viladrich
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
Hello,
I am been spending most of my last solar sessions playing with the Sol'Ex spectro and testing the bandpass of solar Ha filters. The results are interesting ...
The spectro is also very usefull to check the tuning of the filters on Ha line. In fact, it proved that the tuning with the Ha lamp was right on spot :-)
I had a quick imaging session on June 16 with good seeing condition. We can seen a lot of small umbral dots in the sunspot.
http://astrosurf.com/viladrich/astro/so ... B1920..jpg
Clear skies
Christian
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Re: AR2883 on June 16 with the Hat 8 and double stack Ha
Post by p_zetner »
Beautiful result, Christian.
It will be interesting to see what you have come up with in the filter testing!
Peter
Valtori
Has thanked: 312 times
Been thanked: 182 times
Post by Valtori »
Hello Christian,
Very impressive DS in Ha HR!
Val
H-Alpha
Has thanked: 1674 times
Been thanked: 982 times
Post by H-Alpha »
Excellent Hi-Res results as always Christian!
Thanks for sharing.
What SSM did you have for this photo?
Alexandros
Alexandros
Greece
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Excllent result, Christian. As always.
Why don't you use your C11?
christian viladrich
Has thanked: 1 time
Thanks to all :-)
Peter, regarding filters, I probably need one or two more weeks to put things together.
Alexandros, as I was also busy with Sol'Ex spectro, I didn't install the SSM (to many things to do ...). BTW, I received your last pm and try to answer soon.
Valery, unfortunately, the Hat 11 I had years ago was only for testing. I should have kept it ;-)
Christian
Has thanked: 20744 times
Been thanked: 10439 times
Top drawer stuff Christian!
Has thanked: 9294 times
Been thanked: 6129 times
Post by ffellah »
A truly beautiful image, Christian
cmas
Has thanked: 294 times
Been thanked: 248 times
Post by cmas »
Wow! :bow
H-alpha: Baader D-ERF, Sharpstar 61 EDPH II, Altair Astro 102 f/7, Quark, reducer and ASI174mm.
White light: Baader ASSF 115, Sony SEL 200600G, Sony SEL20TC, Sony A7iii.
Images in AstroBin
Images in Flickr
Has thanked: 17925 times
Been thanked: 8892 times
Pure beauty! :bow :hamster:
