6 20 animation
torsinadoc
Has thanked: 1640 times
Been thanked: 878 times
6 20 animation
Post by torsinadoc »
Animation from 9:21am-10:01
Equipment
Lunt 100 single stack, powermate 4x basler 155
processed
AS3
ImPPG/Pixinsight
PiPP to convert to .gif (15fps looping video)
There were high clouds that caused some flashing
Image6-20-21 animation by Diamond, Alan, on Flickr
For direct .gif link
live.staticflickr.com/65535/51260966849_1c25a9c422_o.gif
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Re: 6 20 animation
Post by p_zetner »
Beautiful, wide-field animation!
There's a lot of activity within 1 hour, especially in the prom on the right.
Peter
torsinadoc
Re: 6 20 animation
p_zetner wrote: Sun Jun 20, 2021 10:34 pm Beautiful, wide-field animation!
Peter
Thanks.
H-Alpha
Has thanked: 1674 times
Been thanked: 982 times
Re: 6 20 animation
Post by H-Alpha »
Alan this is fantastic!!! :bow :bow
There is so much detail at the limb as well as on the proms!
Can you please tell us:
If you have a SSM as an indication of your seeing during this capture?
What max value did you use in your histogram? 85%?
It seems the powermate 4x makes a great job. Are you happy from it?
and something last... (sorry for the many questions)
How did you make the animated gif being animated in Flickr? I tried today but failed and then read that this is not possible! what is the magic you did? ;-) And did you upload the entire Gif here, or is it the link that plays in your post? How you make all this?
Best wishes,
Alexandros
Alexandros
Greece
torsinadoc
Re: 6 20 animation
H-Alpha wrote: Mon Jun 21, 2021 12:53 am Alan this is fantastic!!! :bow :bow
Best wishes,
Alexandros
I didnt have my SSM connected. I tossed a few rubbish frames. I used lucky imaging (captured 1000 frames and stacked about 50). I adjust gamma and gain to overexpose the disc but not the spicules (see image for example on prior animation).
Basler174_2.5PM animation settings.png (552.73 KiB) Viewed 293 times
I upload the .gif to Flickr
I clicked share, BBC code and original. I think embed option works, too. The key is the share the ORIGINAL file. Only the original will be the .gif.
The powermate is ok with Ha but not Cak.
Has thanked: 17572 times
Been thanked: 16693 times
Re: 6 20 animation
Post by DeepSolar64 »
That's a nice wide-field pano Animation! Lots of change in a short time.
