Animation from 9:21am-10:01
Equipment
Lunt 100 single stack, powermate 4x basler 155
processed
AS3
ImPPG/Pixinsight
PiPP to convert to .gif (15fps looping video)
There were high clouds that caused some flashing
6-20-21 animation by Diamond, Alan, on Flickr
For direct .gif link
live.staticflickr.com/65535/51260966849_1c25a9c422_o.gif
6 20 animation
- Has thanked: 1640 times
- Been thanked: 878 times
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Re: 6 20 animation
Beautiful, wide-field animation!
There's a lot of activity within 1 hour, especially in the prom on the right.
Peter
Peter
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Re: 6 20 animation
Alan this is fantastic!!!
There is so much detail at the limb as well as on the proms!
Can you please tell us:
If you have a SSM as an indication of your seeing during this capture?
What max value did you use in your histogram? 85%?
It seems the powermate 4x makes a great job. Are you happy from it?
and something last... (sorry for the many questions)
How did you make the animated gif being animated in Flickr? I tried today but failed and then read that this is not possible! what is the magic you did? ;-) And did you upload the entire Gif here, or is it the link that plays in your post? How you make all this?
Alexandros
Alexandros
Alexandros
Greece
Greece
Re: 6 20 animation
I didnt have my SSM connected. I tossed a few rubbish frames. I used lucky imaging (captured 1000 frames and stacked about 50). I adjust gamma and gain to overexpose the disc but not the spicules (see image for example on prior animation). I upload the .gif to FlickrH-Alpha wrote: ↑Mon Jun 21, 2021 12:53 am Alan this is fantastic!!!
Alexandros
I clicked share, BBC code and original. I think embed option works, too. The key is the share the ORIGINAL file. Only the original will be the .gif.
The powermate is ok with Ha but not Cak.
- Been thanked: 16693 times
Re: 6 20 animation
That's a nice wide-field pano Animation! Lots of change in a short time.
